Ms3 pro boost controller questions
How would one go about setting up ms3 pro boost controller to run a fill and vent solenoid setup for co2? Some like the boost leash and other high end boost controller's are able to do. I'd like to be able to set the map I want in the table and let Ms control the duty cycle time based boost would be great as that's what I'm use to running thanks
Re: Ms3 pro boost controller questions
If my memory is correct. Download the current release, 1.5.0 and in the file is a supplemental PDF that goes over the co2 setup, wiring and plumbing
You'll need to be on the 1.5.0 code. Use the dome pressure control settings and use two high current outputs, one for each solenoid.
What size restrictors are recommended for this?
it mentions it here http://www.msextra.com/doc/pdf/Boost-supplement-1.5.pdf
page 8 section 2.2
page 8 section 2.2
2000 ZX-12R LSR turbo Worlds Fastest at 266.5MPH on board video here https://www.youtube.com/watch?v=CruXgKKzBUs
