HELP! sync loss problem...
cardelino18
Post by cardelino18 »
I need some help. i have a 1jzgte non vvti with an ms3x. i wired it up with new shielded wires on crank and cam sensor. i also added a 10kohms resistor (to each cam and crank sensor), ive played with noise filtering settings, and nothing. i need help because im getting very frustated with it. it revs good until around 2800-3000rpm then gets sync loss for a sec, if i keep reving it, it passes and revs clearly after it breaks up.
Attached is a composite logg, actual log of the tunerstudio with settings, and the trigger logger.
any help will be very appreciated!
Thanks in advance!
billr
Re: HELP! sync loss problem...
Post by billr »
Post the MSQ, too.
cardelino18
Witch one is the MSQ?
whittlebeast
Post by whittlebeast »
Your problem is all on the cam sensor. Is that with stock sensors?
cardelino18
whittlebeast wrote:Your problem is all on the cam sensor. Is that with stock sensors?
Yes stock new sensor
cardelino18
Plus new shielded wire, resistor, and new clip
whittlebeast
I elected to get rid of the cam sensor on my Honda motor.
http://www.nbs-stl.com/CrxTypeR/B18C%20Dizzy.jpg
The red Hall in the photo comes from DIY.
Andy
whittlebeast
Can you get to a scope to see what the cam signal looks like?
This is what my crank sensor looks like. My cam sensor looks like a square wave.
Andy
whittlebeast
Are you running the newest 1.5 code? It has some new tricks under the covers.
cardelino18
whittlebeast wrote:Can you get to a scope to see what the cam signal looks like?
Andy
I dont have a scope available unfortunately
cardelino18
whittlebeast wrote:Are you running the newest 1.5 code? It has some new tricks under the covers.
Havent updated it yet
cardelino18
What problem do you see with my cam?
whittlebeast
If you look at that composite log, you can see where the code misses a couple of cam teeth in a row. Look at page 75 in the log.
Andy
cardelino18
whittlebeast wrote:If you look at that composite log, you can see where the code misses a couple of cam teeth in a row. Look at page 75 in the log.
Andy
What could be causing this? ive been trying to fix this for the past 2 months.... it only does it at this point on the RPM, it revs out good after that hickup. I am out of ideas on how to fix this... any help please.
Thanks!
whittlebeast
Can you describe what you have for a can sensor and cam trigger pin. Hall sensor, VR sensor... Pics help for us to figure what is in there now.
Just for reference, here is what I going to for cam sync.
http://www.nbs-stl.com/CrxTypeR/Dizzy3.jpg
And here is the modified stock cam pin and the Hall sensor from DIYAutotune.
But we have the tools to make this sort of thing. Most people don't.
Andy
cardelino18
whittlebeast wrote:Can you describe what you have for a can sensor and cam trigger pin. Hall sensor, VR sensor... Pics help for us to figure what is in there now.
Andy
i think its a VR sensor, i am double checking it with my tuner who is helping me with this issue as well. I am not very techy savvy when it comes to electrical specifics, i just wired it up to all the oem sensors and started to learn alot more than expected lol. Once i have a solid answer i will post it, its a little early here so idk if he is awake.
cardelino18
Andy
Ok i verified with him, it is in deed a VR sensor.
