HELP! sync loss problem...
I need some help. i have a 1jzgte non vvti with an ms3x. i wired it up with new shielded wires on crank and cam sensor. i also added a 10kohms resistor (to each cam and crank sensor), ive played with noise filtering settings, and nothing. i need help because im getting very frustated with it. it revs good until around 2800-3000rpm then gets sync loss for a sec, if i keep reving it, it passes and revs clearly after it breaks up.
Attached is a composite logg, actual log of the tunerstudio with settings, and the trigger logger.
any help will be very appreciated!
Thanks in advance!
Thanks in advance!
Re: HELP! sync loss problem...
Post the MSQ, too.
Witch one is the MSQ?
Your problem is all on the cam sensor. Is that with stock sensors?
Yes stock new sensorwhittlebeast wrote:Your problem is all on the cam sensor. Is that with stock sensors?
Plus new shielded wire, resistor, and new clipcardelino18 wrote:Yes stock new sensorwhittlebeast wrote:Your problem is all on the cam sensor. Is that with stock sensors?
I elected to get rid of the cam sensor on my Honda motor.
http://www.nbs-stl.com/CrxTypeR/B18C%20Dizzy.jpg
The red Hall in the photo comes from DIY.
Andy
Andy
Can you get to a scope to see what the cam signal looks like?
This is what my crank sensor looks like. My cam sensor looks like a square wave.
Andy
Andy
Are you running the newest 1.5 code? It has some new tricks under the covers.
I dont have a scope available unfortunatelywhittlebeast wrote:Can you get to a scope to see what the cam signal looks like?
Andy
Havent updated it yetwhittlebeast wrote:Are you running the newest 1.5 code? It has some new tricks under the covers.
What problem do you see with my cam?whittlebeast wrote:Your problem is all on the cam sensor. Is that with stock sensors?
If you look at that composite log, you can see where the code misses a couple of cam teeth in a row. Look at page 75 in the log.
Andy
Andy
What could be causing this? ive been trying to fix this for the past 2 months.... it only does it at this point on the RPM, it revs out good after that hickup. I am out of ideas on how to fix this... any help please.whittlebeast wrote:If you look at that composite log, you can see where the code misses a couple of cam teeth in a row. Look at page 75 in the log.
Andy
Thanks!
Can you describe what you have for a can sensor and cam trigger pin. Hall sensor, VR sensor... Pics help for us to figure what is in there now.
Just for reference, here is what I going to for cam sync.
http://www.nbs-stl.com/CrxTypeR/Dizzy3.jpg
And here is the modified stock cam pin and the Hall sensor from DIYAutotune.
But we have the tools to make this sort of thing. Most people don't.
Andy
Andy
i think its a VR sensor, i am double checking it with my tuner who is helping me with this issue as well. I am not very techy savvy when it comes to electrical specifics, i just wired it up to all the oem sensors and started to learn alot more than expected lol. Once i have a solid answer i will post it, its a little early here so idk if he is awake.whittlebeast wrote:Can you describe what you have for a can sensor and cam trigger pin. Hall sensor, VR sensor... Pics help for us to figure what is in there now.
Andy
Andy
Ok i verified with him, it is in deed a VR sensor.
