Just got this installed and I'm a little unclear where to change settings.
Under tools/calibrate map/baro is it the 6400 map and if so what about the values listed at the voltages? Leave them as they are?
Do I need to do anything under the general settIngs? (The two independent sensor option)
Thanks for the help.
Map Daddy upgrade/ settings?
66 Mustang Turbo 6.0 LS on MS3X 80lb Deka injectors Tunerstudio Ultra and MS3 1.5.1
Re: Map Daddy upgrade/ settings?
You will want to set two independent sensors and calibrate both as the MPX6400.
