Hallo,
i've read that the internal knock module uses the LED and JS11. So far so clear.
But i just want to confirm if it is necessary to remove the LED driver components if they are installed on the main board?
If the driver components effect the knock module it should be sufficiant to remove the 1k resistors R26, R27 and R29) and let the transistors and LEDs installed - correct?
Best regards
Internal Knock Module and LEDs - component removal?
Honda CRX B16A1 Turbo | MS3 running | pre1.5.1 beta7 Firmware | 24/1 Dual Wheel | COP ignition | 725cc ID injectors
Re: Internal Knock Module and LEDs - component removal?
No mention of this has ever been made, in the manual or in discussions.
And it does not do any harm to leave them in place.dontz125 wrote:No mention of this has ever been made, in the manual or in discussions.
Thanks a lot
Hello all,
Same as above I have internal knock module installed with MS3X, however I had already installed all standard LED drivers as instructed in the MS3 build manual
Now when I enable "internal" knock setting in TS, LED's 14 and 16 are on permanently when power is supplied to the MS.
Is this normal? I know it was mentioned above that the LED hardware does not have to be removed, but I want to check that it's normal for the LED's to be constantly on, and double confirm that this in no way affects the function of the Knock module.
Is it advisable to open up the case and snip the legs off of the LED's?
Dan
Dan
It shouldn't have any adverse impact. If you want to remove anything, it is the base resistors to the drive transistors that would need removing i.e. R26, R27, R29.
Ok I'll see how accessible they are when I have the case off.
