MS3 release 1.5.0
While tuning my closed loop boost control found an strange behavior, overboost cut hits on my target table values not on my maximun kpa set of 270.
I had set my targets to 250 first and max kpa to 270 and always hitting spark cut limiter. So I reduced my targets to 230 kpa and start hitting earlier. So found in logs that status2: 96 that is overboots and spark cut at > 230 kpa, but my max kpa limiter is set to 270, changed to 300 and same behavior. Have not tried turning it off.
Why is status:2 96 when kpa > 230 that is my target boost value?
Also what is {status2 & 8} it is not defined on ini file or what would be status2: 60?
Thank you.
Bug or feature on boost control hitting spark cut?
Re: Bug or feature on boost control hitting spark cut?
I think you have Boost Tolerance enabled at 5kPa above target.
Thank you very much. I just enabled it trying to troubleshoot another issue. So tolerance acts over target values and not max kpa limit.?
I tried turning off overboost protection and works fine up to 280kpa til redline at 7500 rpm. But I was asking for only 200 kpa.
Anyway more cl boost control tuning and all set.
I'll try with tolerance off.
SOLVED.!!!
SOLVED.!!!
Tolerance relates to your target.
e.g. if at lower RPM you are requesting 150kPa but somehow your turbo achieves 200kPa that could be a problem.
Using the boost tolerance allows in effect a variable over-boost. Setting it to 5kPa is too tight though.
