Cool. Thanks Bill. I appreciate all feedback, I'll start looking for all the parts. Will post a project build for it.
Thanks again,
Jeff
Electromotive hpv1
Re: Electromotive hpv1
Sand scorpion
Engine:
2387cc aircooled roller motor
custom intake manifold w/45 lb bosch injectors
LT1 throttle body w/modified 4 wire iac valve
Electromotive dual coil ignition
AEM wideband 02 sensor
60/2 crank trigger wheel
MSD fuel pump
Engine:
MSD fuel pump
I used the HPV-1 60-2 trigger wheel and VR sensor for my MS2, then MS3 install and it has worked flawlessly. I did have to adjust R52 and R56 on the mainboard a little, but that was it.
Porsche 930 3.0 Slantnose
Yes, same here. I set the mainboard pots full CCW and it worked perfectly (MS3).
Yeah I already had to set the pots full ccw to pick up the rpm signal.
Sand scorpion
Engine:
MSD fuel pump
Engine:
MSD fuel pump
