Ok so i wired up the MAP sensor and i picked the aem 5 bar option for the calibration on the settings, problem is that when i go with those settings the map reads ~30kpa with the engine off, and a friend of mine says it should read 100kpa, so when i adjust it to read 100kpa with engine off, its off under boost by around 10psi. my boost gauge reads 15psi, but my map sensor is reading around 115-120kpa... what am i doing wrong?
Per the aem instructions : http://aemelectronics.com/files/instruc ... Sensor.pdf
signal grnd - grounded to the body
sensor power (5v) - tapped it into the TPS sensor wire
signal (input) - the wire from ms3x that reads ext-map
i set the reading on the setting to ext-map.
Also, i noticed that to get a very accurate reading from my A/F gauge, i needed to ground it to the same ground of the ms3x. is that the same for the MAP sensor?
any help would be really appreciated!
Thanks in advance guys!
Calibrating AEM 5 bar MAP
Re: Calibrating AEM 5 bar MAP
Sensor ground absolutely needs to go to the MS sensor ground input pin.
Personal Vehicle:
Personal Vehicle:
