Launch Control won't activate
I have launch control set to Digital Switched in 2. I've tried grounding it to multiple points that I know are good grounds, but the Launch control light will not turn on. It's enabled in TunerStudios. I've tried different throttle positions, still won't turn on the launch light. This is all key on, engine off just to check wiring. Am I doing something wrong, or does the engine have to be running to activate launch control (even just the light)? Any help would be great. Thanks
Re: Launch Control won't activate
Mine is doing the same and I'm on digital switch #1 with the same set up
I also tried a Digital Frequency and it didn't make any difference. I'm already using the Analog Inputs for other things, so I can't use them...I just can't figure out why it's not working. Good to know I'm not the only one with this issue! I was starting to think my luck was just bad...hopefully Matt or somebody will be able to tell us what we're doing wrong.
I know you have to use a digital switch. So that's right. I just don't know why I can't test it
Engine needs to be running, or at least rpm input from something like a jimstim
Yes engine has to be running
Okay, I will be trying that tomorrow. Thanks!
Did you get yours to work
