So when I initially setup my car I was running pump gas and meth injection.
I have the ms3-pro controlling the meth pump thru a pwm output on a solid state relay. And I use the meth injection set up menu on what to pulse width by rpm etc.
I now added a flex fuel sensor to be able to run E85. I would like to shut off the meth when running higher ethanol contents.
I think that I would be able to do this using another output of the ms3 to control a regular relay to power the solid state relay using a generic output. To only output at a ethanol content of say below 40%.
Which would work but I'm all out of outputs.
I was wondering if there was any other way of doing this?
It would be nice if this was in the firmware someway to be able to control this in the setting for the meth injection or flex fuel setup menus.
Meth injection and flex fuel
