25°C - 450 ohm
75°C - 80 ohm
125°C - 22 ohm
I'm trying to determine a good bias value using the instructions below, but I only get garbage in Mike Soultanian's Custom CLT VBScript.
Normally we want the middle of the ADC voltage range (i.e., 2.5 Volts) to correspond roughly to the middle of the sensors most widely used range.
For example, with a GM temperature sensor, the resistance at 80F is about 2500 Ohms, so
2.5 = 5 * [(2500)/(Rbias + 2500)] and Rbias = 2500/(2.5/5) - 2500 = 2500
This explains why the GM temperature sensors uses a 2K49 Ohm resistor.
The sensors range is 25°C to 125°C, so the middle is 75°C in my case, with a resistance of 80 ohm.
Hence, Rbias = 80/(2.5/5) - 80 = 80 ohm -> 82 ohm
Plugging this into the vb script gives me values of -3.5°C to 62.7°C.
No matter what value I choose a bias never gives me a useable range, so what am I doing wrong? Is my temp range too small?
Code: Select all
//-- Custom coolant factor include file generated by
//-- Mike Soultanian's Custom CLT VBScript - 28/03/2017 19:14:04
//-- This file was created with the algorithm used in Megatune 2.25
//-- Bias = 82
//-- ADC Resolution = 1024
//-- Temperature range: 25F to 145F
//-- Resistance tInput
//-- 450 ohm 298,2K (25C) 25
//-- 190 ohm 323,2K (50C) 50
//-- 14 ohm 418,2K (145C) 145
#ifndef GCC_BUILD
#pragma ROM_VAR CLT_ROM
#endif
const int cltfactor_table[1024] LOOKUP_ATTR = {
// ADC Volts Temp Ohms
900, // 0 0 32,2 0
900, // 1 0 32,2 0,1
900, // 2 0,01 32,2 0,2
900, // 3 0,01 32,2 0,2
900, // 4 0,02 32,2 0,3
900, // 5 0,02 32,2 0,4
900, // 6 0,03 32,2 0,5
900, // 7 0,03 32,2 0,6
900, // 8 0,04 32,2 0,6
900, // 9 0,04 32,2 0,7
900, // 10 0,05 32,2 0,8
900, // 11 0,05 32,2 0,9
900, // 12 0,06 32,2 1
900, // 13 0,06 32,2 1,1
900, // 14 0,07 32,2 1,1
900, // 15 0,07 32,2 1,2
900, // 16 0,08 32,2 1,3
900, // 17 0,08 32,2 1,4
900, // 18 0,09 32,2 1,5
900, // 19 0,09 32,2 1,6
900, // 20 0,1 32,2 1,6
900, // 21 0,1 32,2 1,7
900, // 22 0,11 32,2 1,8
900, // 23 0,11 32,2 1,9
900, // 24 0,12 32,2 2
900, // 25 0,12 32,2 2,1
900, // 26 0,13 32,2 2,1
900, // 27 0,13 32,2 2,2
900, // 28 0,14 32,2 2,3
900, // 29 0,14 32,2 2,4
900, // 30 0,15 32,2 2,5
900, // 31 0,15 32,2 2,6
900, // 32 0,16 32,2 2,6
900, // 33 0,16 32,2 2,7
900, // 34 0,17 32,2 2,8
900, // 35 0,17 32,2 2,9
900, // 36 0,18 32,2 3
900, // 37 0,18 32,2 3,1
900, // 38 0,19 32,2 3,2
900, // 39 0,19 32,2 3,2
900, // 40 0,2 32,2 3,3
900, // 41 0,2 32,2 3,4
900, // 42 0,21 32,2 3,5
900, // 43 0,21 32,2 3,6
900, // 44 0,22 32,2 3,7
900, // 45 0,22 32,2 3,8
900, // 46 0,22 32,2 3,9
900, // 47 0,23 32,2 3,9
900, // 48 0,23 32,2 4
900, // 49 0,24 32,2 4,1
900, // 50 0,24 32,2 4,2
900, // 51 0,25 32,2 4,3
900, // 52 0,25 32,2 4,4
900, // 53 0,26 32,2 4,5
900, // 54 0,26 32,2 4,6
900, // 55 0,27 32,2 4,7
900, // 56 0,27 32,2 4,7
900, // 57 0,28 32,2 4,8
900, // 58 0,28 32,2 4,9
900, // 59 0,29 32,2 5
900, // 60 0,29 32,2 5,1
900, // 61 0,3 32,2 5,2
900, // 62 0,3 32,2 5,3
900, // 63 0,31 32,2 5,4
900, // 64 0,31 32,2 5,5
900, // 65 0,32 32,2 5,6
900, // 66 0,32 32,2 5,7
900, // 67 0,33 32,2 5,7
900, // 68 0,33 32,2 5,8
900, // 69 0,34 32,2 5,9
900, // 70 0,34 32,2 6
900, // 71 0,35 32,2 6,1
900, // 72 0,35 32,2 6,2
900, // 73 0,36 32,2 6,3
900, // 74 0,36 32,2 6,4
900, // 75 0,37 32,2 6,5
900, // 76 0,37 32,2 6,6
900, // 77 0,38 32,2 6,7
900, // 78 0,38 32,2 6,8
900, // 79 0,39 32,2 6,9
900, // 80 0,39 32,2 7
900, // 81 0,4 32,2 7,1
900, // 82 0,4 32,2 7,1
900, // 83 0,41 32,2 7,2
900, // 84 0,41 32,2 7,3
900, // 85 0,42 32,2 7,4
900, // 86 0,42 32,2 7,5
900, // 87 0,43 32,2 7,6
900, // 88 0,43 32,2 7,7
900, // 89 0,43 32,2 7,8
900, // 90 0,44 32,2 7,9
900, // 91 0,44 32,2 8
900, // 92 0,45 32,2 8,1
900, // 93 0,45 32,2 8,2
900, // 94 0,46 32,2 8,3
900, // 95 0,46 32,2 8,4
900, // 96 0,47 32,2 8,5
900, // 97 0,47 32,2 8,6
900, // 98 0,48 32,2 8,7
900, // 99 0,48 32,2 8,8
900, // 100 0,49 32,2 8,9
900, // 101 0,49 32,2 9
900, // 102 0,5 32,2 9,1
900, // 103 0,5 32,2 9,2
900, // 104 0,51 32,2 9,3
900, // 105 0,51 32,2 9,4
900, // 106 0,52 32,2 9,5
900, // 107 0,52 32,2 9,6
900, // 108 0,53 32,2 9,7
900, // 109 0,53 32,2 9,8
900, // 110 0,54 32,2 9,9
900, // 111 0,54 32,2 10
900, // 112 0,55 32,2 10,1
900, // 113 0,55 32,2 10,2
900, // 114 0,56 32,2 10,3
900, // 115 0,56 32,2 10,4
900, // 116 0,57 32,2 10,5
900, // 117 0,57 32,2 10,6
900, // 118 0,58 32,2 10,7
900, // 119 0,58 32,2 10,8
900, // 120 0,59 32,2 10,9
900, // 121 0,59 32,2 11
900, // 122 0,6 32,2 11,1
900, // 123 0,6 32,2 11,2
900, // 124 0,61 32,2 11,3
900, // 125 0,61 32,2 11,4
900, // 126 0,62 32,2 11,5
900, // 127 0,62 32,2 11,6
900, // 128 0,63 32,2 11,7
900, // 129 0,63 32,2 11,8
900, // 130 0,64 32,2 11,9
900, // 131 0,64 32,2 12
900, // 132 0,65 32,2 12,1
900, // 133 0,65 32,2 12,3
900, // 134 0,65 32,2 12,4
900, // 135 0,66 32,2 12,5
900, // 136 0,66 32,2 12,6
900, // 137 0,67 32,2 12,7
900, // 138 0,67 32,2 12,8
900, // 139 0,68 32,2 12,9
900, // 140 0,68 32,2 13
900, // 141 0,69 32,2 13,1
900, // 142 0,69 32,2 13,2
900, // 143 0,7 32,2 13,3
900, // 144 0,7 32,2 13,4
900, // 145 0,71 32,2 13,5
900, // 146 0,71 32,2 13,7
900, // 147 0,72 32,2 13,8
900, // 148 0,72 32,2 13,9
900, // 149 0,73 32,2 14
900, // 150 0,73 32,2 14,1
900, // 151 0,74 32,2 14,2
900, // 152 0,74 32,2 14,3
900, // 153 0,75 32,2 14,4
900, // 154 0,75 32,2 14,5
900, // 155 0,76 32,2 14,6
900, // 156 0,76 32,2 14,8
900, // 157 0,77 32,2 14,9
900, // 158 0,77 32,2 15
900, // 159 0,78 32,2 15,1
900, // 160 0,78 32,2 15,2
900, // 161 0,79 32,2 15,3
900, // 162 0,79 32,2 15,4
900, // 163 0,8 32,2 15,5
900, // 164 0,8 32,2 15,7
900, // 165 0,81 32,2 15,8
900, // 166 0,81 32,2 15,9
900, // 167 0,82 32,2 16
900, // 168 0,82 32,2 16,1
900, // 169 0,83 32,2 16,2
900, // 170 0,83 32,2 16,3
900, // 171 0,84 32,2 16,5
900, // 172 0,84 32,2 16,6
900, // 173 0,85 32,2 16,7
900, // 174 0,85 32,2 16,8
900, // 175 0,86 32,2 16,9
900, // 176 0,86 32,2 17
900, // 177 0,87 32,2 17,2
900, // 178 0,87 32,2 17,3
900, // 179 0,87 32,2 17,4
900, // 180 0,88 32,2 17,5
900, // 181 0,88 32,2 17,6
900, // 182 0,89 32,2 17,7
900, // 183 0,89 32,2 17,9
900, // 184 0,9 32,2 18
900, // 185 0,9 32,2 18,1
900, // 186 0,91 32,2 18,2
900, // 187 0,91 32,2 18,3
900, // 188 0,92 32,2 18,5
900, // 189 0,92 32,2 18,6
900, // 190 0,93 32,2 18,7
900, // 191 0,93 32,2 18,8
900, // 192 0,94 32,2 18,9
900, // 193 0,94 32,2 19,1
900, // 194 0,95 32,2 19,2
900, // 195 0,95 32,2 19,3
900, // 196 0,96 32,2 19,4
900, // 197 0,96 32,2 19,6
900, // 198 0,97 32,2 19,7
900, // 199 0,97 32,2 19,8
900, // 200 0,98 32,2 19,9
900, // 201 0,98 32,2 20,1
900, // 202 0,99 32,2 20,2
900, // 203 0,99 32,2 20,3
900, // 204 1 32,2 20,4
900, // 205 1 32,2 20,6
900, // 206 1,01 32,2 20,7
900, // 207 1,01 32,2 20,8
900, // 208 1,02 32,2 20,9
900, // 209 1,02 32,2 21,1
900, // 210 1,03 32,2 21,2
900, // 211 1,03 32,2 21,3
900, // 212 1,04 32,2 21,4
900, // 213 1,04 32,2 21,6
900, // 214 1,05 32,2 21,7
900, // 215 1,05 32,2 21,8
900, // 216 1,06 32,2 21,9
900, // 217 1,06 32,2 22,1
900, // 218 1,07 32,2 22,2
900, // 219 1,07 32,2 22,3
900, // 220 1,08 32,2 22,5
900, // 221 1,08 32,2 22,6
900, // 222 1,09 32,2 22,7
900, // 223 1,09 32,2 22,9
900, // 224 1,09 32,2 23
900, // 225 1,1 32,2 23,1
900, // 226 1,1 32,2 23,3
900, // 227 1,11 32,2 23,4
900, // 228 1,11 32,2 23,5
900, // 229 1,12 32,2 23,6
900, // 230 1,12 32,2 23,8
900, // 231 1,13 32,2 23,9
900, // 232 1,13 32,2 24,1
900, // 233 1,14 32,2 24,2
900, // 234 1,14 32,2 24,3
900, // 235 1,15 32,2 24,5
900, // 236 1,15 32,2 24,6
900, // 237 1,16 32,2 24,7
900, // 238 1,16 32,2 24,9
900, // 239 1,17 32,2 25
900, // 240 1,17 32,2 25,1
900, // 241 1,18 32,2 25,3
900, // 242 1,18 32,2 25,4
900, // 243 1,19 32,2 25,5
900, // 244 1,19 32,2 25,7
900, // 245 1,2 32,2 25,8
900, // 246 1,2 32,2 26
900, // 247 1,21 32,2 26,1
900, // 248 1,21 32,2 26,2
900, // 249 1,22 32,2 26,4
900, // 250 1,22 32,2 26,5
900, // 251 1,23 32,2 26,7
900, // 252 1,23 32,2 26,8
900, // 253 1,24 32,2 26,9
900, // 254 1,24 32,2 27,1
900, // 255 1,25 32,2 27,2
900, // 256 1,25 32,2 27,4
900, // 257 1,26 32,2 27,5
900, // 258 1,26 32,2 27,7
900, // 259 1,27 32,2 27,8
900, // 260 1,27 32,2 27,9
900, // 261 1,28 32,2 28,1
900, // 262 1,28 32,2 28,2
900, // 263 1,29 32,2 28,4
900, // 264 1,29 32,2 28,5
900, // 265 1,3 32,2 28,7
900, // 266 1,3 32,2 28,8
900, // 267 1,3 32,2 29
900, // 268 1,31 32,2 29,1
900, // 269 1,31 32,2 29,3
900, // 270 1,32 32,2 29,4
900, // 271 1,32 32,2 29,6
900, // 272 1,33 32,2 29,7
900, // 273 1,33 32,2 29,8
900, // 274 1,34 32,2 30
900, // 275 1,34 32,2 30,1
900, // 276 1,35 32,2 30,3
900, // 277 1,35 32,2 30,4
900, // 278 1,36 32,2 30,6
900, // 279 1,36 32,2 30,8
900, // 280 1,37 32,2 30,9
900, // 281 1,37 32,2 31,1
900, // 282 1,38 32,2 31,2
900, // 283 1,38 32,2 31,4
900, // 284 1,39 32,2 31,5
900, // 285 1,39 32,2 31,7
900, // 286 1,4 32,2 31,8
900, // 287 1,4 32,2 32
900, // 288 1,41 32,2 32,1
900, // 289 1,41 32,2 32,3
900, // 290 1,42 32,2 32,4
900, // 291 1,42 32,2 32,6
900, // 292 1,43 32,2 32,8
900, // 293 1,43 32,2 32,9
900, // 294 1,44 32,2 33,1
900, // 295 1,44 32,2 33,2
900, // 296 1,45 32,2 33,4
900, // 297 1,45 32,2 33,5
900, // 298 1,46 32,2 33,7
900, // 299 1,46 32,2 33,9
900, // 300 1,47 32,2 34
900, // 301 1,47 32,2 34,2
900, // 302 1,48 32,2 34,3
900, // 303 1,48 32,2 34,5
900, // 304 1,49 32,2 34,7
900, // 305 1,49 32,2 34,8
900, // 306 1,5 32,2 35
900, // 307 1,5 32,2 35,2
900, // 308 1,51 32,2 35,3
900, // 309 1,51 32,2 35,5
900, // 310 1,52 32,2 35,7
900, // 311 1,52 32,2 35,8
900, // 312 1,52 32,2 36
900, // 313 1,53 32,2 36,1
900, // 314 1,53 32,2 36,3
900, // 315 1,54 32,2 36,5
900, // 316 1,54 32,2 36,7
900, // 317 1,55 32,2 36,8
900, // 318 1,55 32,2 37
900, // 319 1,56 32,2 37,2
900, // 320 1,56 32,2 37,3
900, // 321 1,57 32,2 37,5
900, // 322 1,57 32,2 37,7
900, // 323 1,58 32,2 37,8
900, // 324 1,58 32,2 38
900, // 325 1,59 32,2 38,2
900, // 326 1,59 32,2 38,4
900, // 327 1,6 32,2 38,5
900, // 328 1,6 32,2 38,7
900, // 329 1,61 32,2 38,9
900, // 330 1,61 32,2 39
900, // 331 1,62 32,2 39,2
900, // 332 1,62 32,2 39,4
900, // 333 1,63 32,2 39,6
900, // 334 1,63 32,2 39,8
900, // 335 1,64 32,2 39,9
900, // 336 1,64 32,2 40,1
900, // 337 1,65 32,2 40,3
900, // 338 1,65 32,2 40,5
900, // 339 1,66 32,2 40,6
900, // 340 1,66 32,2 40,8
900, // 341 1,67 32,2 41
900, // 342 1,67 32,2 41,2
900, // 343 1,68 32,2 41,4
900, // 344 1,68 32,2 41,5
900, // 345 1,69 32,2 41,7
900, // 346 1,69 32,2 41,9
900, // 347 1,7 32,2 42,1
900, // 348 1,7 32,2 42,3
900, // 349 1,71 32,2 42,5
900, // 350 1,71 32,2 42,6
900, // 351 1,72 32,2 42,8
900, // 352 1,72 32,2 43
900, // 353 1,73 32,2 43,2
900, // 354 1,73 32,2 43,4
900, // 355 1,74 32,2 43,6
900, // 356 1,74 32,2 43,8
900, // 357 1,74 32,2 44
900, // 358 1,75 32,2 44,1
900, // 359 1,75 32,2 44,3
900, // 360 1,76 32,2 44,5
900, // 361 1,76 32,2 44,7
900, // 362 1,77 32,2 44,9
900, // 363 1,77 32,2 45,1
900, // 364 1,78 32,2 45,3
900, // 365 1,78 32,2 45,5
900, // 366 1,79 32,2 45,7
900, // 367 1,79 32,2 45,9
900, // 368 1,8 32,2 46,1
900, // 369 1,8 32,2 46,3
900, // 370 1,81 32,2 46,5
900, // 371 1,81 32,2 46,7
900, // 372 1,82 32,2 46,9
900, // 373 1,82 32,2 47,1
900, // 374 1,83 32,2 47,3
900, // 375 1,83 32,2 47,5
900, // 376 1,84 32,2 47,7
900, // 377 1,84 32,2 47,9
900, // 378 1,85 32,2 48,1
900, // 379 1,85 32,2 48,3
900, // 380 1,86 32,2 48,5
900, // 381 1,86 32,2 48,7
900, // 382 1,87 32,2 48,9
900, // 383 1,87 32,2 49,1
900, // 384 1,88 32,2 49,3
900, // 385 1,88 32,2 49,5
900, // 386 1,89 32,2 49,7
900, // 387 1,89 32,2 49,9
900, // 388 1,9 32,2 50,1
900, // 389 1,9 32,2 50,3
900, // 390 1,91 32,2 50,5
900, // 391 1,91 32,2 50,7
900, // 392 1,92 32,2 50,9
900, // 393 1,92 32,2 51,2
900, // 394 1,93 32,2 51,4
900, // 395 1,93 32,2 51,6
900, // 396 1,94 32,2 51,8
900, // 397 1,94 32,2 52
900, // 398 1,95 32,2 52,2
900, // 399 1,95 32,2 52,4
900, // 400 1,96 32,2 52,6
900, // 401 1,96 32,2 52,9
900, // 402 1,96 32,2 53,1
900, // 403 1,97 32,2 53,3
900, // 404 1,97 32,2 53,5
900, // 405 1,98 32,2 53,7
900, // 406 1,98 32,2 54
900, // 407 1,99 32,2 54,2
900, // 408 1,99 32,2 54,4
900, // 409 2 32,2 54,6
900, // 410 2 32,2 54,8
900, // 411 2,01 32,2 55,1
900, // 412 2,01 32,2 55,3
900, // 413 2,02 32,2 55,5
900, // 414 2,02 32,2 55,7
900, // 415 2,03 32,2 56
900, // 416 2,03 32,2 56,2
900, // 417 2,04 32,2 56,4
900, // 418 2,04 32,2 56,7
900, // 419 2,05 32,2 56,9
900, // 420 2,05 32,2 57,1
900, // 421 2,06 32,2 57,3
900, // 422 2,06 32,2 57,6
900, // 423 2,07 32,2 57,8
900, // 424 2,07 32,2 58
900, // 425 2,08 32,2 58,3
900, // 426 2,08 32,2 58,5
900, // 427 2,09 32,2 58,7
900, // 428 2,09 32,2 59
900, // 429 2,1 32,2 59,2
900, // 430 2,1 32,2 59,5
900, // 431 2,11 32,2 59,7
900, // 432 2,11 32,2 59,9
900, // 433 2,12 32,2 60,2
900, // 434 2,12 32,2 60,4
900, // 435 2,13 32,2 60,7
900, // 436 2,13 32,2 60,9
900, // 437 2,14 32,2 61,2
900, // 438 2,14 32,2 61,4
900, // 439 2,15 32,2 61,6
900, // 440 2,15 32,2 61,9
900, // 441 2,16 32,2 62,1
900, // 442 2,16 32,2 62,4
900, // 443 2,17 32,2 62,6
900, // 444 2,17 32,2 62,9
900, // 445 2,17 32,2 63,1
900, // 446 2,18 32,2 63,4
900, // 447 2,18 32,2 63,6
900, // 448 2,19 32,2 63,9
900, // 449 2,19 32,2 64,1
900, // 450 2,2 32,2 64,4
900, // 451 2,2 32,2 64,7
900, // 452 2,21 32,2 64,9
900, // 453 2,21 32,2 65,2
900, // 454 2,22 32,2 65,4
900, // 455 2,22 32,2 65,7
900, // 456 2,23 32,2 65,9
900, // 457 2,23 32,2 66,2
900, // 458 2,24 32,2 66,5
900, // 459 2,24 32,2 66,7
900, // 460 2,25 32,2 67
900, // 461 2,25 32,2 67,3
900, // 462 2,26 32,2 67,5
900, // 463 2,26 32,2 67,8
900, // 464 2,27 32,2 68,1
900, // 465 2,27 32,2 68,3
900, // 466 2,28 32,2 68,6
900, // 467 2,28 32,2 68,9
900, // 468 2,29 32,2 69,1
900, // 469 2,29 32,2 69,4
900, // 470 2,3 32,2 69,7
900, // 471 2,3 32,2 70
900, // 472 2,31 32,2 70,2
900, // 473 2,31 32,2 70,5
900, // 474 2,32 32,2 70,8
900, // 475 2,32 32,2 71,1
900, // 476 2,33 32,2 71,4
900, // 477 2,33 32,2 71,6
900, // 478 2,34 32,2 71,9
900, // 479 2,34 32,2 72,2
900, // 480 2,35 32,2 72,5
900, // 481 2,35 32,2 72,8
900, // 482 2,36 32,2 73,1
900, // 483 2,36 32,2 73,3
900, // 484 2,37 32,2 73,6
900, // 485 2,37 32,2 73,9
900, // 486 2,38 32,2 74,2
900, // 487 2,38 32,2 74,5
900, // 488 2,39 32,2 74,8
900, // 489 2,39 32,2 75,1
900, // 490 2,39 32,2 75,4
900, // 491 2,4 32,2 75,7
900, // 492 2,4 32,2 76
900, // 493 2,41 32,2 76,3
900, // 494 2,41 32,2 76,6
900, // 495 2,42 32,2 76,9
900, // 496 2,42 32,2 77,2
900, // 497 2,43 32,2 77,5
900, // 498 2,43 32,2 77,8
900, // 499 2,44 32,2 78,1
900, // 500 2,44 32,2 78,4
900, // 501 2,45 32,2 78,7
900, // 502 2,45 32,2 79
900, // 503 2,46 32,2 79,3
900, // 504 2,46 32,2 79,6
900, // 505 2,47 32,2 79,9
900, // 506 2,47 32,2 80,3
900, // 507 2,48 32,2 80,6
900, // 508 2,48 32,2 80,9
900, // 509 2,49 32,2 81,2
900, // 510 2,49 32,2 81,5
900, // 511 2,5 32,2 81,8
900, // 512 2,5 32,2 82,2
900, // 513 2,51 32,2 82,5
900, // 514 2,51 32,2 82,8
900, // 515 2,52 32,2 83,1
900, // 516 2,52 32,2 83,5
900, // 517 2,53 32,2 83,8
900, // 518 2,53 32,2 84,1
900, // 519 2,54 32,2 84,4
900, // 520 2,54 32,2 84,8
900, // 521 2,55 32,2 85,1
900, // 522 2,55 32,2 85,4
900, // 523 2,56 32,2 85,8
900, // 524 2,56 32,2 86,1
900, // 525 2,57 32,2 86,4
900, // 526 2,57 32,2 86,8
900, // 527 2,58 32,2 87,1
900, // 528 2,58 32,2 87,5
900, // 529 2,59 32,2 87,8
900, // 530 2,59 32,2 88,2
900, // 531 2,6 32,2 88,5
900, // 532 2,6 32,2 88,8
900, // 533 2,61 32,2 89,2
900, // 534 2,61 32,2 89,5
900, // 535 2,61 32,2 89,9
900, // 536 2,62 32,2 90,3
900, // 537 2,62 32,2 90,6
900, // 538 2,63 32,2 91
900, // 539 2,63 32,2 91,3
900, // 540 2,64 32,2 91,7
900, // 541 2,64 32,2 92
900, // 542 2,65 32,2 92,4
900, // 543 2,65 32,2 92,8
900, // 544 2,66 32,2 93,1
900, // 545 2,66 32,2 93,5
900, // 546 2,67 32,2 93,9
900, // 547 2,67 32,2 94,2
900, // 548 2,68 32,2 94,6
900, // 549 2,68 32,2 95
900, // 550 2,69 32,2 95,3
900, // 551 2,69 32,2 95,7
900, // 552 2,7 32,2 96,1
900, // 553 2,7 32,2 96,5
900, // 554 2,71 32,2 96,9
900, // 555 2,71 32,2 97,2
900, // 556 2,72 32,2 97,6
900, // 557 2,72 32,2 98
900, // 558 2,73 32,2 98,4
900, // 559 2,73 32,2 98,8
900, // 560 2,74 32,2 99,2
900, // 561 2,74 32,2 99,6
900, // 562 2,75 32,2 100
900, // 563 2,75 32,2 100,4
900, // 564 2,76 32,2 100,8
900, // 565 2,76 32,2 101,2
900, // 566 2,77 32,2 101,6
900, // 567 2,77 32,2 102
900, // 568 2,78 32,2 102,4
900, // 569 2,78 32,2 102,8
900, // 570 2,79 32,2 103,2
900, // 571 2,79 32,2 103,6
900, // 572 2,8 32,2 104
900, // 573 2,8 32,2 104,4
900, // 574 2,81 32,2 104,8
900, // 575 2,81 32,2 105,2
900, // 576 2,82 32,2 105,7
900, // 577 2,82 32,2 106,1
900, // 578 2,83 32,2 106,5
900, // 579 2,83 32,2 106,9
900, // 580 2,83 32,2 107,4
900, // 581 2,84 32,2 107,8
900, // 582 2,84 32,2 108,2
900, // 583 2,85 32,2 108,6
900, // 584 2,85 32,2 109,1
900, // 585 2,86 32,2 109,5
900, // 586 2,86 32,2 110
900, // 587 2,87 32,2 110,4
900, // 588 2,87 32,2 110,8
900, // 589 2,88 32,2 111,3
900, // 590 2,88 32,2 111,7
900, // 591 2,89 32,2 112,2
900, // 592 2,89 32,2 112,6
900, // 593 2,9 32,2 113,1
900, // 594 2,9 32,2 113,5
900, // 595 2,91 32,2 114
900, // 596 2,91 32,2 114,5
900, // 597 2,92 32,2 114,9
900, // 598 2,92 32,2 115,4
900, // 599 2,93 32,2 115,8
900, // 600 2,93 32,2 116,3
900, // 601 2,94 32,2 116,8
900, // 602 2,94 32,2 117,3
900, // 603 2,95 32,2 117,7
900, // 604 2,95 32,2 118,2
900, // 605 2,96 32,2 118,7
900, // 606 2,96 32,2 119,2
900, // 607 2,97 32,2 119,6
900, // 608 2,97 32,2 120,1
900, // 609 2,98 32,2 120,6
900, // 610 2,98 32,2 121,1
900, // 611 2,99 32,2 121,6
900, // 612 2,99 32,2 122,1
900, // 613 3 32,2 122,6
900, // 614 3 32,2 123,1
900, // 615 3,01 32,2 123,6
900, // 616 3,01 32,2 124,1
900, // 617 3,02 32,2 124,6
900, // 618 3,02 32,2 125,1
900, // 619 3,03 32,2 125,6
900, // 620 3,03 32,2 126,2
1448, // 621 3,04 62,7 126,7
1445, // 622 3,04 62,5 127,2
1443, // 623 3,04 62,4 127,7
1441, // 624 3,05 62,3 128,2
1438, // 625 3,05 62,1 128,8
1436, // 626 3,06 62 129,3
1434, // 627 3,06 61,9 129,8
1431, // 628 3,07 61,7 130,4
1429, // 629 3,07 61,6 130,9
1427, // 630 3,08 61,5 131,5
1424, // 631 3,08 61,3 132
1422, // 632 3,09 61,2 132,5
1419, // 633 3,09 61,1 133,1
1417, // 634 3,1 60,9 133,6
1415, // 635 3,1 60,8 134,2
1412, // 636 3,11 60,7 134,8
1410, // 637 3,11 60,6 135,3
1408, // 638 3,12 60,4 135,9
1405, // 639 3,12 60,3 136,5
1403, // 640 3,13 60,2 137
1400, // 641 3,13 60 137,6
1398, // 642 3,14 59,9 138,2
1396, // 643 3,14 59,8 138,8
1393, // 644 3,15 59,6 139,3
1391, // 645 3,15 59,5 139,9
1388, // 646 3,16 59,4 140,5
1386, // 647 3,16 59,2 141,1
1384, // 648 3,17 59,1 141,7
1381, // 649 3,17 59 142,3
1379, // 650 3,18 58,8 142,9
1377, // 651 3,18 58,7 143,5
1374, // 652 3,19 58,6 144,1
1372, // 653 3,19 58,4 144,7
1369, // 654 3,2 58,3 145,3
1367, // 655 3,2 58,2 146
1365, // 656 3,21 58 146,6
1362, // 657 3,21 57,9 147,2
1360, // 658 3,22 57,8 147,8
1357, // 659 3,22 57,6 148,5
1355, // 660 3,23 57,5 149,1
1352, // 661 3,23 57,4 149,7
1350, // 662 3,24 57,2 150,4
1348, // 663 3,24 57,1 151
1345, // 664 3,25 57 151,7
1343, // 665 3,25 56,8 152,3
1340, // 666 3,26 56,7 153
1338, // 667 3,26 56,6 153,6
1336, // 668 3,26 56,4 154,3
1333, // 669 3,27 56,3 155
1331, // 670 3,27 56,1 155,6
1328, // 671 3,28 56 156,3
1326, // 672 3,28 55,9 157
1323, // 673 3,29 55,7 157,7
1321, // 674 3,29 55,6 158,4
1319, // 675 3,3 55,5 159,1
1316, // 676 3,3 55,3 159,7
1314, // 677 3,31 55,2 160,4
1311, // 678 3,31 55,1 161,1
1309, // 679 3,32 54,9 161,9
1306, // 680 3,32 54,8 162,6
1304, // 681 3,33 54,7 163,3
1301, // 682 3,33 54,5 164
1299, // 683 3,34 54,4 164,7
1296, // 684 3,34 54,2 165,5
1294, // 685 3,35 54,1 166,2
1292, // 686 3,35 54 166,9
1289, // 687 3,36 53,8 167,7
1287, // 688 3,36 53,7 168,4
1284, // 689 3,37 53,6 169,2
1282, // 690 3,37 53,4 169,9
1279, // 691 3,38 53,3 170,7
1277, // 692 3,38 53,2 171,4
1274, // 693 3,39 53 172,2
1272, // 694 3,39 52,9 173
1269, // 695 3,4 52,7 173,8
1267, // 696 3,4 52,6 174,5
1264, // 697 3,41 52,5 175,3
1262, // 698 3,41 52,3 176,1
1259, // 699 3,42 52,2 176,9
1257, // 700 3,42 52 177,7
1254, // 701 3,43 51,9 178,5
1252, // 702 3,43 51,8 179,3
1249, // 703 3,44 51,6 180,1
1247, // 704 3,44 51,5 181
1244, // 705 3,45 51,3 181,8
1242, // 706 3,45 51,2 182,6
1239, // 707 3,46 51,1 183,5
1237, // 708 3,46 50,9 184,3
1234, // 709 3,47 50,8 185,2
1232, // 710 3,47 50,6 186
1229, // 711 3,48 50,5 186,9
1227, // 712 3,48 50,4 187,7
1224, // 713 3,48 50,2 188,6
1222, // 714 3,49 50,1 189,5
1219, // 715 3,49 49,9 190,4
1216, // 716 3,5 49,8 191,2
1214, // 717 3,5 49,7 192,1
1211, // 718 3,51 49,5 193
1209, // 719 3,51 49,4 193,9
1206, // 720 3,52 49,2 194,9
1204, // 721 3,52 49,1 195,8
1201, // 722 3,53 48,9 196,7
1198, // 723 3,53 48,8 197,6
1196, // 724 3,54 48,7 198,6
1193, // 725 3,54 48,5 199,5
1191, // 726 3,55 48,4 200,4
1188, // 727 3,55 48,2 201,4
1186, // 728 3,56 48,1 202,4
1183, // 729 3,56 47,9 203,3
1180, // 730 3,57 47,8 204,3
1178, // 731 3,57 47,7 205,3
1175, // 732 3,58 47,5 206,3
1173, // 733 3,58 47,4 207,3
1170, // 734 3,59 47,2 208,3
1167, // 735 3,59 47,1 209,3
1165, // 736 3,6 46,9 210,3
1162, // 737 3,6 46,8 211,3
1159, // 738 3,61 46,6 212,3
1157, // 739 3,61 46,5 213,4
1154, // 740 3,62 46,3 214,4
1152, // 741 3,62 46,2 215,5
1149, // 742 3,63 46 216,5
1146, // 743 3,63 45,9 217,6
1144, // 744 3,64 45,8 218,7
1141, // 745 3,64 45,6 219,7
1138, // 746 3,65 45,5 220,8
1136, // 747 3,65 45,3 221,9
1133, // 748 3,66 45,2 223
1130, // 749 3,66 45 224,2
1128, // 750 3,67 44,9 225,3
1125, // 751 3,67 44,7 226,4
1122, // 752 3,68 44,6 227,5
1119, // 753 3,68 44,4 228,7
1117, // 754 3,69 44,3 229,8
1114, // 755 3,69 44,1 231
1111, // 756 3,7 44 232,2
1109, // 757 3,7 43,8 233,4
1106, // 758 3,7 43,7 234,6
1103, // 759 3,71 43,5 235,8
1100, // 760 3,71 43,4 237
1098, // 761 3,72 43,2 238,2
1095, // 762 3,72 43,1 239,4
1092, // 763 3,73 42,9 240,6
1089, // 764 3,73 42,7 241,9
1087, // 765 3,74 42,6 243,1
1084, // 766 3,74 42,4 244,4
1081, // 767 3,75 42,3 245,7
1078, // 768 3,75 42,1 247
1076, // 769 3,76 42 248,3
1073, // 770 3,76 41,8 249,6
1070, // 771 3,77 41,7 250,9
1067, // 772 3,77 41,5 252,2
1064, // 773 3,78 41,4 253,5
1062, // 774 3,78 41,2 254,9
1059, // 775 3,79 41 256,2
1056, // 776 3,79 40,9 257,6
1053, // 777 3,8 40,7 259
1050, // 778 3,8 40,6 260,4
1048, // 779 3,81 40,4 261,8
1045, // 780 3,81 40,3 263,2
1042, // 781 3,82 40,1 264,6
1039, // 782 3,82 39,9 266,1
1036, // 783 3,83 39,8 267,5
1033, // 784 3,83 39,6 269
1030, // 785 3,84 39,5 270,5
1027, // 786 3,84 39,3 271,9
1025, // 787 3,85 39,1 273,4
1022, // 788 3,85 39 275
1019, // 789 3,86 38,8 276,5
1016, // 790 3,86 38,7 278
1013, // 791 3,87 38,5 279,6
1010, // 792 3,87 38,3 281,1
1007, // 793 3,88 38,2 282,7
1004, // 794 3,88 38 284,3
1001, // 795 3,89 37,8 285,9
998, // 796 3,89 37,7 287,5
995, // 797 3,9 37,5 289,2
992, // 798 3,9 37,4 290,8
989, // 799 3,91 37,2 292,5
986, // 800 3,91 37 294,2
983, // 801 3,91 36,9 295,9
980, // 802 3,92 36,7 297,6
977, // 803 3,92 36,5 299,3
974, // 804 3,93 36,4 301
971, // 805 3,93 36,2 302,8
968, // 806 3,94 36 304,6
965, // 807 3,94 35,8 306,4
962, // 808 3,95 35,7 308,2
959, // 809 3,95 35,5 310
956, // 810 3,96 35,3 311,8
953, // 811 3,96 35,2 313,7
950, // 812 3,97 35 315,6
947, // 813 3,97 34,8 317,5
944, // 814 3,98 34,7 319,4
941, // 815 3,98 34,5 321,3
937, // 816 3,99 34,3 323,2
934, // 817 3,99 34,1 325,2
931, // 818 4 34 327,2
928, // 819 4 33,8 329,2
925, // 820 4,01 33,6 331,2
922, // 821 4,01 33,4 333,3
919, // 822 4,02 33,3 335,3
915, // 823 4,02 33,1 337,4
912, // 824 4,03 32,9 339,5
909, // 825 4,03 32,7 341,7
906, // 826 4,04 32,5 343,8
903, // 827 4,04 32,4 346
899, // 828 4,05 32,2 348,2
896, // 829 4,05 32 350,4
893, // 830 4,06 31,8 352,6
890, // 831 4,06 31,6 354,9
886, // 832 4,07 31,5 357,2
883, // 833 4,07 31,3 359,5
880, // 834 4,08 31,1 361,8
876, // 835 4,08 30,9 364,2
873, // 836 4,09 30,7 366,6
870, // 837 4,09 30,5 369
866, // 838 4,1 30,4 371,4
863, // 839 4,1 30,2 373,9
860, // 840 4,11 30 376,4
856, // 841 4,11 29,8 378,9
853, // 842 4,12 29,6 381,5
849, // 843 4,12 29,4 384
846, // 844 4,13 29,2 386,6
843, // 845 4,13 29 389,3
839, // 846 4,13 28,8 391,9
836, // 847 4,14 28,7 394,6
832, // 848 4,14 28,5 397,3
829, // 849 4,15 28,3 400,1
825, // 850 4,15 28,1 402,9
822, // 851 4,16 27,9 405,7
818, // 852 4,16 27,7 408,6
815, // 853 4,17 27,5 411,4
811, // 854 4,17 27,3 414,4
808, // 855 4,18 27,1 417,3
804, // 856 4,18 26,9 420,3
800, // 857 4,19 26,7 423,3
797, // 858 4,19 26,5 426,4
793, // 859 4,2 26,3 429,5
790, // 860 4,2 26,1 432,6
786, // 861 4,21 25,9 435,8
782, // 862 4,21 25,7 439
779, // 863 4,22 25,5 442,3
775, // 864 4,22 25,3 445,6
771, // 865 4,23 25,1 448,9
767, // 866 4,23 24,9 452,3
764, // 867 4,24 24,7 455,7
760, // 868 4,24 24,4 459,2
756, // 869 4,25 24,2 462,7
752, // 870 4,25 24 466,3
749, // 871 4,26 23,8 469,9
745, // 872 4,26 23,6 473,5
741, // 873 4,27 23,4 477,2
737, // 874 4,27 23,2 481
733, // 875 4,28 23 484,8
729, // 876 4,28 22,7 488,7
725, // 877 4,29 22,5 492,6
721, // 878 4,29 22,3 496,5
717, // 879 4,3 22,1 500,5
713, // 880 4,3 21,9 504,6
709, // 881 4,31 21,6 508,7
705, // 882 4,31 21,4 512,9
701, // 883 4,32 21,2 517,2
697, // 884 4,32 21 521,5
693, // 885 4,33 20,7 525,9
689, // 886 4,33 20,5 530,3
685, // 887 4,34 20,3 534,8
681, // 888 4,34 20 539,4
677, // 889 4,35 19,8 544
672, // 890 4,35 19,6 548,7
668, // 891 4,35 19,3 553,5
664, // 892 4,36 19,1 558,4
660, // 893 4,36 18,9 563,3
655, // 894 4,37 18,6 568,3
651, // 895 4,37 18,4 573,4
647, // 896 4,38 18,2 578,5
642, // 897 4,38 17,9 583,8
638, // 898 4,39 17,7 589,1
634, // 899 4,39 17,4 594,5
629, // 900 4,4 17,2 600
625, // 901 4,4 16,9 605,6
620, // 902 4,41 16,7 611,3
616, // 903 4,41 16,4 617,1
611, // 904 4,42 16,2 622,9
607, // 905 4,42 15,9 628,9
602, // 906 4,43 15,7 635
597, // 907 4,43 15,4 641,2
593, // 908 4,44 15,1 647,4
588, // 909 4,44 14,9 653,8
583, // 910 4,45 14,6 660,4
578, // 911 4,45 14,4 667
574, // 912 4,46 14,1 673,7
569, // 913 4,46 13,8 680,6
564, // 914 4,47 13,6 687,6
559, // 915 4,47 13,3 694,7
554, // 916 4,48 13 702
549, // 917 4,48 12,7 709,4
544, // 918 4,49 12,5 716,9
539, // 919 4,49 12,2 724,6
534, // 920 4,5 11,9 732,4
529, // 921 4,5 11,6 740,4
524, // 922 4,51 11,3 748,6
519, // 923 4,51 11 756,9
513, // 924 4,52 10,7 765,3
508, // 925 4,52 10,5 774
503, // 926 4,53 10,2 782,8
497, // 927 4,53 9,9 791,8
492, // 928 4,54 9,6 801
487, // 929 4,54 9,3 810,4
481, // 930 4,55 9 820
476, // 931 4,55 8,6 829,8
470, // 932 4,56 8,3 839,8
464, // 933 4,56 8 850,1
459, // 934 4,57 7,7 860,5
453, // 935 4,57 7,4 871,2
447, // 936 4,57 7,1 882,2
441, // 937 4,58 6,7 893,4
435, // 938 4,58 6,4 904,9
429, // 939 4,59 6,1 916,6
423, // 940 4,59 5,7 928,7
417, // 941 4,6 5,4 941
411, // 942 4,6 5,1 953,6
405, // 943 4,61 4,7 966,6
399, // 944 4,61 4,4 979,8
393, // 945 4,62 4 993,5
386, // 946 4,62 3,7 1007,4
380, // 947 4,63 3,3 1021,8
373, // 948 4,63 3 1036,5
367, // 949 4,64 2,6 1051,6
360, // 950 4,64 2,2 1067,1
353, // 951 4,65 1,8 1083,1
346, // 952 4,65 1,5 1099,5
339, // 953 4,66 1,1 1116,4
333, // 954 4,66 0,7 1133,7
325, // 955 4,67 0,3 1151,6
318, // 956 4,67 -0,1 1170
311, // 957 4,68 -0,5 1189
304, // 958 4,68 -0,9 1208,6
296, // 959 4,69 -1,3 1228,7
289, // 960 4,69 -1,7 1249,5
281, // 961 4,7 -2,2 1271
274, // 962 4,7 -2,6 1293,2
266, // 963 4,71 -3 1316,1
258, // 964 4,71 -3,5 1339,8
900, // 965 4,72 32,2 1364,3
900, // 966 4,72 32,2 1389,7
900, // 967 4,73 32,2 1416
900, // 968 4,73 32,2 1443,2
900, // 969 4,74 32,2 1471,4
900, // 970 4,74 32,2 1500,8
900, // 971 4,75 32,2 1531,2
900, // 972 4,75 32,2 1562,8
900, // 973 4,76 32,2 1595,7
900, // 974 4,76 32,2 1630
900, // 975 4,77 32,2 1665,6
900, // 976 4,77 32,2 1702,8
900, // 977 4,78 32,2 1741,6
900, // 978 4,78 32,2 1782,1
900, // 979 4,78 32,2 1824,5
900, // 980 4,79 32,2 1868,8
900, // 981 4,79 32,2 1915,3
900, // 982 4,8 32,2 1964
900, // 983 4,8 32,2 2015,1
900, // 984 4,81 32,2 2068,9
900, // 985 4,81 32,2 2125,5
900, // 986 4,82 32,2 2185,2
900, // 987 4,82 32,2 2248,2
900, // 988 4,83 32,2 2314,7
900, // 989 4,83 32,2 2385,2
900, // 990 4,84 32,2 2460
900, // 991 4,84 32,2 2539,4
900, // 992 4,85 32,2 2624
900, // 993 4,85 32,2 2714,2
900, // 994 4,86 32,2 2810,6
900, // 995 4,86 32,2 2913,9
900, // 996 4,87 32,2 3024,9
900, // 997 4,87 32,2 3144,4
900, // 998 4,88 32,2 3273,4
900, // 999 4,88 32,2 3413,3
900, // 1000 4,89 32,2 3565,2
900, // 1001 4,89 32,2 3731
900, // 1002 4,9 32,2 3912,6
900, // 1003 4,9 32,2 4112,3
900, // 1004 4,91 32,2 4333,1
900, // 1005 4,91 32,2 4578,3
900, // 1006 4,92 32,2 4852,5
900, // 1007 4,92 32,2 5160,9
900, // 1008 4,93 32,2 5510,4
900, // 1009 4,93 32,2 5909,9
900, // 1010 4,94 32,2 6370,8
900, // 1011 4,94 32,2 6908,5
900, // 1012 4,95 32,2 7544
900, // 1013 4,95 32,2 8306,6
900, // 1014 4,96 32,2 9238,7
900, // 1015 4,96 32,2 10403,7
900, // 1016 4,97 32,2 11901,7
900, // 1017 4,97 32,2 13899
900, // 1018 4,98 32,2 16695,2
900, // 1019 4,98 32,2 20889,5
900, // 1020 4,99 32,2 27880
900, // 1021 4,99 32,2 41861
900, // 1022 5 32,2 83804
900}; // 1023 5 32,2 0
#ifndef GCC_BUILD
#pragma ROM_VAR DEFAULT
#endif
