stepper motor to push open throttles
Does anyone know of a suitable stepper motor to open the throttles at idle? Need a pretty strong one.
Re: stepper motor to push open throttles
How much push force do you need? How much speed of the stroke? Both will depend on the length of the throttle lever it will push on.
Need to measure it somehow, force is doable, but speed ? It's for idle control, so not very fast.
Oh, also tell what total stroke on the actuator you think you need.
20 mm will suffice.
ford eecIII systems used this. think early to mid 80's ford tbi
http://www.rockauto.com/en/catalog/ford ... valve,6072
Yes Aussie EA ford falcon CFI had one. Fairly large and rather ugly. Difficult to source as they were only produced in small numbers compared to mpfi.
Cheers Luke
Cheers Luke
Is that a stepper or is that just a throttle stop ? Otherwise this would be a great option.
It is a stepper. The photo I posted shows the rod in retracted position in one and extended on the other.
Cheers Luke
Cheers Luke
Thanks !!!
Any idea how many amps that stepper needs ?
Another option, cruse control module from a first gen dodge. it is a PWM valve powered by vacuum. the PWM signal determines how much the cable is pulled. The module has a wide range and is very strong pulling. (I use it to control a cut-out by mega squirt). it Fails in the closed position as well. Safety first.....
92 Dakota Work in progress (ms3x)
I'm pretty sure the Ford device is a DC servo, not a stepper.
That would surprise me. A servo normally is much larger as it has a position feedback.Matt Cramer wrote:I'm pretty sure the Ford device is a DC servo, not a stepper.
Na I have temporarily run one from my own stand alone stepper controller and just bench testing. Belled out the coils to find correct connection. I ran 2 of the 2bbl (aussie) a la side draft webbers for a little while. I did not have the real estate to use the idle control but as I had them I had a play. Definitely could extend and retract. No idea on what they pulled for current or how long they last or accuracy, just confirmed they worked. As I said before they are rare parts over here.Matt Cramer wrote:I'm pretty sure the Ford device is a DC servo, not a stepper.
Just checked it has 2 coils, 30ohm each.
Cheers Luke
Cheers Luke
Slowhemi, can you tell me what the connection is?
Assuming 30 ohm and 12V feed, would mean it would draw 30/12 = 2,5A. (motor is 12 X 2,5 = 30W) When the MS3X board only allows 0,5A this will cause a problem. Not sure how to get around that. Relays between each wire maybe ?
BTW : the part can be easily had on ebay. Of course with shipping and everything else it becomes rather expensive. Got it here in the mean time. I noticed the rather thick wiring attached to it, so that's why I questioned the current draw. It seems that I was right to question this. Didn't think of measuring reistance myself. Thanks for that.
The manual shows the GM type steppers as having a nominal resistance of 35 to 45 ohm so these are not a lot different. DC resistance measurement is not a true indication of coil current but it is indicative. Your math is a bit off. Ohms law is V=IR and I=V/R so that's 12/30 which is 0.4A. Watts= VA so 12x0.4= 4.8W
On my motor one coil is Black/Grey and Grey the other coil is Black and Grey/Black.
Cheers Luke
Cheers Luke
Well turns out the motor I have is faulty. I opened the thing up and it it is not actually a stepper motor, it is a simple dc motor. Black and Grey/Black is a switch that opens if too much pressure is on the actuator and Black/Grey and Grey run the motor but the motor has limit switches for max and minimum extension. Really have to apologize for the bum steer about it being a stepper.
Cheers Luke
Cheers Luke
Correct on the amps and power. My faultslow_hemi6 wrote:Well turns out the motor I have is faulty. I opened the thing up and it it is not actually a stepper motor, it is a simple dc motor. Black and Grey/Black is a switch that opens if too much pressure is on the actuator and Black/Grey and Grey run the motor but the motor has limit switches for max and minimum extension. Really have to apologize for the bum steer about it being a stepper.
I have different colors on the one I have here : black, red, yellow and purple.
So basically it's just a throttle stop then ? d***
