I keep getting the following warning when opening my project file : "Warning: cranktaper_time row:4, col:0, One or more value higher than maximum: 16.0, Set to the maximum value: 15.0".
I have checked the crank taper curve settings in the Startup/Idle section and no such entries appear.
MS3 V 1.50 release
TS 3.0
Thanks,
Dave W
Warning Message at Startup
Re: Warning Message at Startup
it seems that you have configured an event number that's too high..in fact 200 events could be quite some time, try 0.10.20.30 etc.in the event row
Thank You Linzerl,
Rescaling the events has eliminated the warning message.
I am still curious though regarding the row;4 col;0 reference.
Anyone know where that comes from?
The 5th (0,1,2,3,4) number in the events column is the first one that's too big (160)..150 seems the largest number that works.
Yes OK, but the table I see in TS has 2 rows and 6 columns. That's the part that I find confusing. The references do not match the table structure.
