Cam signal fault
Darragh791
Cam signal fault
Post by Darragh791 »
Im trying to run sequential injection on my vauxhall c20xe using the standard hall type sensor, all is wired in correctly i think but i a am getting a cam fault can anyone point me in the direction of the problem. Thanks
grom_e30
Re: Cam signal fault
Post by grom_e30 »
that log shows no cam signal at all, have you adjusted the pots on the ms3x card correctly?
Darragh791
I am unsure if i logged it correctly there, i redone the log with the spark mode changed check and see if its ok now.
grom_e30
Post by grom_e30 »
you can use log crank and cam, or leave it set for dual wheel with missing tooth. is the cam signal meant to be a single tooth?
Darragh791
yeah its meant to be a single tooth
rickb794
Post by rickb794 »
Did you get this sorted?
I am in the same situation...
grom_e30
Post by grom_e30 »
rickb794 wrote:Did you get this sorted?
id start a new thread posting the tune and a composite log
