Cam signal fault
Cam signal fault
Im trying to run sequential injection on my vauxhall c20xe using the standard hall type sensor, all is wired in correctly i think but i a am getting a cam fault can anyone point me in the direction of the problem. Thanks
Re: Cam signal fault
that log shows no cam signal at all, have you adjusted the pots on the ms3x card correctly?
I am unsure if i logged it correctly there, i redone the log with the spark mode changed check and see if its ok now.
you can use log crank and cam, or leave it set for dual wheel with missing tooth. is the cam signal meant to be a single tooth?
yeah its meant to be a single tooth
Did you get this sorted?
I am in the same situation...
id start a new thread posting the tune and a composite logrickb794 wrote:Did you get this sorted?
