Dear megasquirt owners,
I am in the final stage in my vvt swap the first startup. However this is pretty much where I'm stuck.
The megasquirt doesn't want to connect to my laptop. I use a USB to serial adapter from DIYautotune, the ecu is from them aswell.
A rundown of what is happening:
- The portchecker program sais there is no ecu to be found but there is 1 valid port.
- The first and fourth led are on, so the ecu has power
- The fuses F1 and F3: F1 has 0.76V and F3 gets nothing.
Things done to the car:
- '03 VVT 1.8l engine
- '03 TPS
- '03 coils/ignition system (modified the NA ignitor by connecting 1/2 , 4/5, 7/8 together, and doing the wiring changes as descriped by the VVT megathread by Sav on the turbo miata forum: https://www.miataturbo.net/engine-perfo ... ead-80469/ )
- MS pnp pro 90 - 93 miata
What is going on with my megasquirt? google searching didn't help and the MS3 manual troubleschooting guide didn't help eather
Thank you so much in advance,
Cedric
MSpnp pro vvt swapped 91 miata issues
Re: MSpnp pro vvt swapped 91 miata issues
No need to post in multiple locations...... As I stated in your other post you have no 5VREF likely due to a miswired TPS and if an MS3 Pro loses 5V (any variant as far as I know) it will not function.
Support the developers!
