sequential no start on GM. 3.57 / 1.5.0 / MS3X
Re: sequential no start on GM. 3.57 / 1.5.0 / MS3X
Postby TheMU47 » Fri May 19, 2017 11:37 am
new logs
2017-05-19_14.35.04.msl
(62.37 KiB) Downloaded 2 times
2017-05-19_11.09.56.csv
(23.71 KiB) Downloaded 3 times
TheMU47
Postby TheMU47 » Fri May 19, 2017 11:43 am
thanks for your help so far billr. I appreciate it.
TPS is wired to 5V ref. IAT is not. I have that wired to main board IAT SIG and the other end to a shared ground with CLT ground. I'll check the sensor return circuit from IAT, CLT and TPS.
found CLT was on correct sensor return circuit, but IAT and TPS were on a looky loo. Now all 3 sensors using return circuit SNSR RET.
TheMU47
Postby billr » Fri May 19, 2017 1:58 pm
Reverse the wires to your (VR) CKP sensor and post a new tooth log.
billr
Postby TheMU47 » Fri May 19, 2017 3:02 pm
swapped the two wires to the crank sensor.
2017-05-19_18.00.20.msl
(73.09 KiB) Downloaded 2 times
2017-05-19_18.01.12.csv
(24.26 KiB) Downloaded 1 time
TheMU47
Postby billr » Fri May 19, 2017 7:52 pm
That tooth log looks good now. Are you getting sparking and injector pulses now? Do you have a timing light now? I always suggest using a simple light, not one of those dial-back ones; they seem to work more reliably.
billr
Postby TheMU47 » Sat May 20, 2017 10:55 am
starts and runs. Thanks a lot billr. you've really made my day/week
TheMU47
Postby billr » Sat May 20, 2017 11:01 am
Post a recent MSQ and MSL, we may be able to offer beneficial suggestions on tuning it.
billr
Postby TheMU47 » Sun May 21, 2017 7:39 pm
billr wrote:Post a recent MSQ and MSL, we may be able to offer beneficial suggestions on tuning it.
cool. I'll do that tomorrow. thanks.
TheMU47
Postby TheMU47 » Tue May 23, 2017 12:54 pm
a few files.
1st - hard to start
2nd - cold running
3rd - warm running
2017-05-23_15.39.30.msl
hard start
(113.31 KiB) Downloaded 1 time
2017-05-23_15.41.07.msl
cold - running
(474.31 KiB) Downloaded 2 times
2017-05-23_15.49.03.msl
warm - running
(201.09 KiB) Downloaded 2 times
TheMU47
Postby TheMU47 » Tue May 23, 2017 12:56 pm
here's the current tune.
hey thanks for looking. I really like that this community helps out like this.
MU4752317.msq
the current tune
(284.71 KiB) Downloaded 1 time
TheMU47
Postby TheMU47 » Tue May 23, 2017 2:03 pm
I've noticed that my oxygen sensor is out of range during autotune. I have a very free flowing exhaust. during the running msq's I have a restricter in the pipe with a 3/4" opening to try and get a stable O2. didn't seem to work out as I had hoped. Also, the charger was hooked up again. Like I said, its tough to get started right now.
the joys of custom builds. LOL
TheMU47
Postby billr » Tue May 23, 2017 5:29 pm
First, turn off the EGO control and ignore AFR readings from the NB sensor. NB sensors are near-useless for tuning. I don't know if the 14point7 "Spartans" are shipping now, but that's what I suggest for a WB; they are in the $100-150 range.
You have constant sync loss when cold, but not when hot. That needs to be fixed, but it's not at all clear to me what is going on there. I'll have to go back and study this thread again later.
Your "req_fuel" is very low, so I gotta ask: Have you flowed them for rate and dead-time? That becomes quite critical when "req_fuel" values get low. Are yours high-Z injectors (how many ohms?)?
It looks like this cranks at about 200 rpm, so lower the cranking threshold to about 250 rpm (presently 700). This will keep idle fueling and spark timing from dropping into "cranking" settings until rpm drops clear down to 250.
I see you have no IAC, and MAP drops noticeably during cranking. I would open up the idle stop-screw on the throttle to give it some more air while cranking.
The cranking pulse is rather skimpy, I would make it a straight line between the present 10F and 180F values, as a first guess.
The spark table is rather odd, but let's wait on that until the sync-loss issue is gone and the injector characteristics are verified.
PS: you still don't have a timing light?
billr
Postby TheMU47 » Wed May 24, 2017 8:20 am
I have a wideband O2, an Innovate LC2. Had the setting wrong. I'm seeing IAT here on dash mode. It's usually around 90- 100 degrees out here. I also use phenolic spacers, so intake temps don't get as hot when warmed up. I have not flowed the injectors. Siemens Deka 83#/hr high impedance. I used the fuel calculator for required fuel. 122 ci, 4 cyl. I will have a timing light shortly. Currently no income, so spending money is tough right now. Made the other changes recommended. I did switch to wide band instead of turning off a/f Ego. If it should be off, I'll switch it off. I'd like to see what it does reading the wideband.
TheMU47
Postby TheMU47 » Thu May 25, 2017 2:13 pm
latest log - warm.
2017-05-25_17.13.54.msl
(109.46 KiB) Not downloaded yet
TheMU47
Previous
Return to MS3 General Support
Users browsing this forum: No registered users and 4 guests
