Hello,
I have a Ford 302 that I have converting from carb to injection, that I am trying to start for the first time. I have taken a 5.0 base tune and have adjusted it for my setup. I have also found a spreadsheet with the specifications for my injectors. My problem is that I do not know how to interrupt it. Can somone please help me decifer and input the specs into my tune. Thanks is advance.
Injector data setup
Re: Injector data setup
Yours? M-9593-B302; Ford Motorsports data for "Fat" 30# Injectors
https://performanceparts.ford.com/parts ... 3-b302.pdf
This spreadsheet calculates for MS2 & MS3.
https://docs.google.com/spreadsheets/d/ ... =302838282
Thanks! I will give it a try.
