Continental Flex fuel sensor
Re: Continental Flex fuel sensor
So today i started this car i mentioned in my previous post and now it did throw the flex fault, i changed the low freq to 49 and it stopped showing the fault... why could this be?
Some of these didn't quite hit the 50 Hz low / 150 Hz high targets due to production tolerances.
The next beta firmware has some tweaks to assist with this.
Water is a contaminant for those sensors---esp 30% water.
1% or so will stay in suspension, but gasoline wont stay in suspension above a certain water concentration.
That's how the little water mix ethanol% test cylinders work...
the water mixes with the alcohol and the gasoline separates out, leaving a visible transition.
IPA will mix fine with gasoline as long as the water % is low.
(Its used as diesel or gas "drygas")
Great to know its been assisted, i managed to solve a problem on a car im working on and will test the alcohol content and the basic fuel/timing setup... also the blended boost tables.
