Cant get Traction Control to engage
BLR
Post by BLR »
Just as the title says. Confirmed the TC enable input is working properly.
Thanks in advance,
Brian
UPDATE:
It worked before I did a firmware change and now it doesn't. I noticed that the settings for CAN VSS and gear selection were wrong so I changed them, but it still don't work.
Im running out of ideas!!!
The msq and msl have been updated to the changed settings.
BLR
Re: Cant get Traction Control to engage
Post by BLR »
Anyone? Please
Sent from my SM-G930F using Tapatalk
Speedy_G
Post by Speedy_G »
Have you tried to set "Enable Input" to "off"
so that its always active.
I've read that your input is working correctly.
But maybe there is a bug in the firmware.
I would give it a try.
dontz125
Post by dontz125 »
Have you tried reverting to the previous firmware & tune to confirm that it still works?
Check your TCU project to confirm that the TC is still set up to use CAN. With the previous firmware, did you incorporate the TC into the main project? This allows you to check the settings without having to swap projects.
BLR
Post by BLR »
It works now!
I set the input to off as Speedy_G said and it worked! That's when I noticed I had the input as Dig Freq 2, not Dig In 2 as it should be.... Brain Fart
Thanks for your guys help, I really appreciate it.
This forum is a lot of the reason I decided to go with megasquirt and I'm glad I did. Now if I can get my closed loop boost control to work :)
