VSS reads very high
VSS reads very high
Has anyone else noticed that their VSS reads at least double what it should? Mine both do, front and rear. It has me totally confused. I will get a log up soon. Here is my msq though. Reading the 5 teeth bolting my rotor to my hub with DIYs Hall Sensor.
Re: VSS reads very high
Here is a quick datalog of me driving through a parking lot in 1st gear. This is not a land speed car, 3100 rpm is not 51mph in 1st. Is anyone else seeing bizarre stuff like this when triggering off of teeth? There are 5 mounting tabs on the back of each rotor.
Do I just have the settings wrong somehow? They feel pretty straight forward to me. Is there a metric to American conversion in there somewhere that I am missing? Thanks for any help you guys can offer.
The car has an MS3-Pro, running 1.5 beta1 firmware.
I have found that putting in a value of 10 teeth helps with the speed. Not sure how accurate it is though.
I've used that feature a number of times and it works ok. Is there any chance that your sensor might be reading two edges somehow?
I had this same thing happen targeting the rear of the wheel studs on my application. There are little divots in the studs and the sensor is sometimes seeing two events. I was advised to pull the sensor back from the studs until I saw the problem go away, but I have not had time to pull the wheel hub and adjust. Instead I am using the pulses per mile where it is easy to do the conversion math to get the sensor to read correctly based on GPS speed as a stopgap measure.
Okay, that actually makes sense. I have had the feature work fine previously. I adjusted my rear one the other dash and now it reads double, my mounting tabs have a flush mounted allen head bolt in them and i know for sure that the sensor is passing over the keyhole. I didn't realise that would count as an edge. Makes complete sense though. Thanks!
Hope you get it sorted! Please update if this was the issue.
