Hi
Im installing a ms3 onto a bus, 3.7L 4 cyl
The bus uses 24v (two batteries in series) but the ecu will be fed only 12v from the first battery , is there no risk in this setup for the ecu?
MS3 in chinnese Changan Bus
Re: MS3 in chinnese Changan Bus
I tested the ms3 board with the jimstim to see if my ckp vr circuit was ok.
For some reason 60-2 is not emulated right by the stim... i tested 36-2-2-2 and it syncs perfectly.
Played with pots for the 60-2 setup and no sync.
