cuts out and sputters after sitting hot all day....
so when i get ready to leave work, car is "warm" after sitting for 7 hrs, she pops and bucks at about 1500 rpm. then after a bit, she is fine. fine all day. fine when parked and ran cold or hot. just have this issue after it sits a few hours.... maybe crank sensor heat issue? not sure. but i see someitng on the comp logger...
81 Porsche 928. 5L 16v, MS3X CNP- full sequential
Re: cuts out and sputters after sitting hot all day....
Ignition log seems fine, get a "real" datalog of it popping and bucking.
Graduate of EFI University.
What I'm guessing happens on my car (which does much the same) is fuel evaporates entirely from the rails - or just vapour locks - after stopping the engine hot. If I stop the engine before things heat up fully, the next start is excellent What I found helps most is to run the pump for about 10 seconds before attempting a start. It then starts ok and will idle reliably for ever within a very short time.ducman82 wrote:so when i get ready to leave work, car is "warm" after sitting for 7 hrs, she pops and bucks at about 1500 rpm. then after a bit, she is fine. fine all day. fine when parked and ran cold or hot. just have this issue after it sits a few hours.... maybe crank sensor heat issue? not sure. but i see someitng on the comp logger...
It's something I've intended sorting properly. But it's an old car, and means it would be very difficult for a thief to start and drive off in.
it does this when it cuts.....
then after a few min of driving "interesting driving" it clears up...
checked the crank sensor. tight as can be
hmmmmmm
hmmmmmm
