With a fully wamed up engine, throttle response is very good. Blipping the throttle reacts very fast, no lean spike and AFR's go in the 12 region and fall back to stoich.
With a cold engine though, blipping the throttle results in an extreme lean condition where the engine nearly stalls.
I'm not sure where to adjust things to resolve this, any hints? More ASE?
I didn't take a log, I'll do so in the morning;
blipping the throttle when cold = full lean
2016 Westfield SEiW MX5 1.8 - 6sp - Torsen - MSM turbo - MS3 Pro - 2.3kg/hp
Re: blipping the throttle when cold = full lean
have you tried adjusting the 'cold accel multiplier(%)'
currently at 110%, I'll raise it and see what happens.
