VSS1 & VSS2 wiring
anastos
VSS1 & VSS2 wiring
Post by anastos »
Hi All,
Running MS3 V1.5.0 with MS3X currently I have VSS1 connected to Cam In and it works fine. The signal input from the sensor (1989 BMW E30 VSS switch on Diff) is digital 0-12V. I want add VSS2 which will be a VR ABS WSS. My plan is to relocate VSS1 so as to make the conditioning circuit for Cam In available for the VR sensor. Where can I safely route the 0-12V digital signal? The tooth count on VSS1 is 9, tire diameter 23, I calculate the frequency to be under 300Hz
Dave W
grom_e30
Re: VSS1 & VSS2 wiring
Post by grom_e30 »
do you have the ms3x card as the switch inputs table, launch ect will work great for the e30 diff sensor
anastos
Post by anastos »
So... launch In, Nitrous In etc would work well?
Dave W
grom_e30
Post by grom_e30 »
yeah im using launch in on my e30
anastos
Post by anastos »
Tank You Grom_E30
