Relay activated after X seconds after ms3 is on
vitoos
Post by vitoos »
Hi, I would like to activate a relay with PT1 after the ms3 is powered up, is this the function to set ?? thank you
prof315
Re: Relay activated after X seconds after ms3 is on
Post by prof315 »
Yes
Support the developers!
kaeman
Post by kaeman »
That looks correct to me, I did the same kind of setup, only I used the rpm signal to turn on the power relay for my ignition coils, I set it for 10 rpm and that way when I first power up the ms3 or turn on the key the ignition coils are not powered up until I start cranking the engine.
Sounds like the standard function of the "fuel punp relay" output, but without the safety features. Why duplicate it?
piledriver
Post by piledriver »
because it turns on for a few seconds to prime?
I don't see a downside of just using the FP relay to cascade power the ign relay per usual.
You can put that coil power on a switch to flash firmware easily.
AlanJ
Post by AlanJ »
piledriver wrote:because it turns on for a few seconds to prime?
jsmcortina wrote:Sounds like the standard function of the "fuel punp relay" output, but without the safety features. Why duplicate it?
For the purge valve for the fuel tank... An emissions thing for us who willingly comply.....
92 Dakota Work in progress (ms3x)
Raymond_B
Post by Raymond_B »
Right, but you can simply use the FP output, that's what the guys are saying. It can serve to ground trigger several relays and is the preferred way.
http://www.buildpics.org/
AlanJ
Post by AlanJ »
I thought the purge valve was only supposed to open after the engine has been running for 5 seconds, some even wait until it's "warm".
Sorry for the thread jack
Raymond_B
Post by Raymond_B »
You could certainly use an output based off temp, just like running a cooling fan. The MS has no idea what relay is triggering.
Six_Shooter
Post by Six_Shooter »
Why give him a hard time for using an output that he wasn't otherwise using to do EXACTLY what he wants instead of SORTA what he wants? That's what's great about the generic outputs you can set them up to do exactly what you want.
Tha Daily: 2005 Chevy Blazer
