I started to mess around with removing a pin from a Bosch EV1 connector
https://www.diyautotune.com/product/fue ... bosch-ev1/
I don't want to damage the 2 wires or connector where I need to switch wires between 2 connectors.
I've tried bobby-pins and small precision screw drivers.
If you've done this before or understand the best method, I would appreciate the assist.
Bosch EV1 - Pin removal - How to ?
1992 Mustang Conv,
363" Man-o-War (8.2"Deck), Dart Pro-1,
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
Innovate DLG-1 (dual WB O2)
Ignition LS2 coil on plug (Crank trigger+ Explorer cam sensor)
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
Re: Bosch EV1 - Pin removal - How to ?
1992 Mustang Conv,
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
EV1 connectors are pull-to-seat. You need to cut and re-crimp new units on there.
I've figured out a way to push them forward and clip off old pin. Fortunately, I saved the extra pin that is provided in each pack and that will get me through the correction without waiting on new parts.
Thanks for weighing in as it confirmed what I encountered. I watched the videos and none of them helped me. I posted the video in the event it helps someone else.
Thanks again
Thanks again
1992 Mustang Conv,
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
