Hi all, first I'd like to say that I got my MS3 race quad running right and I'm very happy with the results so far.
I'm running pure Alpha-N as primary and MAP as secondary load, secondary tables are 100% yet so not used.
I'm running a 2 wire PWM ICV that is a Benz PWM purge valve, it works well.
I wanted to use the idle VE table to alter the VE on colsed loop, problem is that it uses the primary load (TPS), that remain 0% in my case.
If I could swap MAP for Y load axis, it would be somewhat better, using idle PWM would be as sweet as it could get to get my VE spot on !!
Feature request : Idle VE table Y load axis
