Hi, I am trying to set up a new ms3pro. I am using a Innovate LC-2 controller as my main O2 controller. When I first installed the controller every time I turned on the controller without the engine running the gauge in TS would go red and max out. The fist time the car stated it was running rich so I set TS to auto tune and it was working. The second time I ran the car the o2 reading where off saying that it was running rich, way rich. I also noticed that when ignition is turned on the gauge doesn't max out. I tried to recalibrate the sensor but no luck. I re calibrated TS same thing. I connected the LC-2 to Log works and the controller reads a AFR of 20. I checked the voltage output to the sensor and it is 5 volts. But in TS it reads AFR of 10. I tried to use a analog port but the same results. I have a second O2 using a 14point7 controller but same results. I am not sure what to check next. It was working so I can't understand why it has stopped. Any suggestions?
Wide band not reading
