Boost Control Setups?
I have found Closed loop boost control to be inconsistent. Both by temp changes and according to the gear your in. I am using a 4-port mac valve and using air pressure from the compressor housing. Would going to dome control be more accurate and easier to control with temp swings?
Re: Boost Control Setups?
I've been affected by temperature as well over the past few weeks. 55% used to make 200kpa, now it's taking 65%. Ambient was about 25* hotter than when initially tuned
I'm wondering if I should just go to a 3-port mac valve, uping my WG spring, and seeing if closed loop works better with a 3-port valve.
I havent turned on closed loop boost yet, but ive been running my 3 port mac setup like a 4 port.
meaning, pressure source into the solenoid, 1 port out the solenoid to the bottom of the gates, 1 port out of the solenoid to the top of the gates. The top port needs a tiny bleed hole somewhere.
With this setup, and 10psi springs, i can run 10 psi and at 25psi im mid 30%'s for boost DC at 19hz
this is on my twin 66mm 6.0l LS
I used this setup when it was a stick car and now an auto and it worked well for both.
BootlegTuned
How does that setup act with weather changes?
Yeap this was all life in boost control so I tuned to more percentage in bias duty table with Advanced mode and aggressive PIDs to compensate target overshooting by temp.nathaninwa wrote:I've been affected by temperature as well over the past few weeks. 55% used to make 200kpa, now it's taking 65%. Ambient was about 25* hotter than when initially tuned
BMW 525i, stroker 2.8L, MS3-Pro 1.4.1, BIPs 373, 66mm turbo 30 psi
So does using dome control work any better??
