Hello, im using ms3, firmware 1.4.1 I had the following problem.
During a drag race, arriving at 7500 rpm, the engine turned off abruptly. I thought a fuse had blown or something disconnected. But I did not find anything, I started the engine again and started without problems.
In the datalog I could see that in the 41,385 seconds, the rpm were fixed in 7859 during about 1 second and then the reading was lost. As if the micro had become frizzy.
In the datalog at no time was a lost sync recorded, what scares me is that I have the rpm cut at 7500, If the reading had been below 7500 the ignition and the injectors would have worked totally desynchronized with the motor.
I attach de log.
RPM ISSUE
