Hey all,
Help appreciated - I'm running a 2001 Suzuki Swift 1.3L with coil-on-plug. It looks like a 36-2-2-2, but running this selection I'm getting sync errors on every tooth. The cam has two teeth at 90 degrees.
Also tried wasted COP with no success.
What do I put for Ignition Settings/Wheel decoder?
Attaching images from the engine manual with waveforms and pics.
Thanks!
What's my wheel/trigger setting?
MS3Pro on Suzuki 1.3L Turbo
Garrett turbocharger, Engine ported and polished, Ground cam, Forged dished pistons, Coil-on-plug, Dual fuel pump, Milspec lines
Re: What's my wheel/trigger setting?
+ cam images, and TS screenshot of teeth/crank
Can you post those pictures in an easier to use format? I've tried scrolling around in various ways but am unable to see what is there.
Ignore the above. I tried one more trick and was able to see them. Those are still clumsy for me to see well, but I can see that the CKP wheel is too weird for me to help any. I don't suppose you want to convert to a simple missing-tooth wheel, like 36-1?
Record and attach a composite log. Attach your MSQ.
That ought to be supported as 36-2-2-2
Composite log is mostly blank. Occasionally I get a crank tooth reading with a sync loss for every tooth, but never cam or trigger. Tried wasted COP to circumvent cam; didn't work. I'm baffled.
Is the two-tooth cam at 90deg compatible? The manual reads like only a single tooth cam works with 36-2-2-2..
Tooth log and MSQ attached. Could not upload composite log because there's no data in it. Teeth only show on one of the frames in TS/MLV (no idea if this is related, real or a sw quirk).jsmcortina wrote:Record and attach a composite log. Attach your MSQ.
Using 36-2-2-2. I think it should show RPMs with just primary tach (crank), cam being optional. But, my RPMs are intermittent at best.
Help appreciated!
