Crank Position Sensor Swap From Microsquirt to MS3
fj1289
Post by fj1289 »
I have a Yamaha FJ1100 running on Microsquirt. I am converting it to MS3 base on a V3.0 board. It uses a stock Yamaha trigger wheel and pickup from the fuel injected Yamaha XJR1300. While running Microsquirt, I had to add a resistor across the two wires from the pickup to allow the engine to rev above 5000 rpm.
With the conversion to MS3, do I remove the resistor? If I have a similar issue, would I add the resistor in line with the + signal instead of across both wires?
Thanks!
billr
Re: Crank Position Sensor Swap From Microsquirt to MS3
Post by billr »
This is a VR sensor? I would try it first with no resistor. If a resistor needs to be added it goes inline (series) with the + wire (pin 24 on the V3.0); not between the two wires (parallel). As always, it would help to...
:msq:
fj1289
Post by fj1289 »
Thanks billr. Yes, it is a VR sensor -- I'll try first with no resistor.
I'm just now at the laying out wire runs stage for the MS3 harness - no where close to even generating a datalog yet! It ran great on Microsquirt - just wanting to make use of some of the advantages of the advances made with MS3.
billr
Post by billr »
Wow, you have it running on the Micro with no MSQ? How clever!
I'm teasing you a bit, of course, you were thinking I was asking for the MSQ you intended to run on the MS3. Point is, though, that even the MSQ for that Micro can save asking a lot of questions. It would tell what trigger mode you are going to use, how many CKP teeth, a hint at max rpm, things like that. You probably don't need more help just yet, so really no immediate need for further info from you; but I wanted to get you in the habit of posting the MSQ/MSL...
fj1289
Post by fj1289 »
Good points! I'll dig out the laptop this weekend and post up.
