synch loss with 1.5.0
Re: synch loss with 1.5.0
i would say something changed between 1.4.1 and 1.5.0
also tried different cylinders from 4 to 12 fourstroke but does not seem to make an impact
I know it is a hassle, but any chance you could try the pre-1.5 alpha/beta codes?
http://www.msextra.com/downloads/dev/ms3-obsolete/1-5/
No problem will try to find some time this weekend you need any specific .csv logs?
At the moment, the logs are baffling... you clearly have sync-loss, but also the tooth and composite logs look good?!
Were the tooth-log and MSL taken simultaneously?
No but datalog and tooth logger were begining to give problems very old toshiba tecra with xp
Starting to use sd log
i think i am closing in on something here
saw some errors in 1.5 alpha 1
went back to 1.4.1 to confirm suddenly had errors there
i think it has to do with sequential fueling
you cannot do batch ms3x in 1.4.1 gives a config error
log 207 is from 12 cylinder four-stroke batch injection standard drivers
log 208 is from 12 cylinder four-stroke ms3x semisequentieel
i activated 12 cylinder support in the project properties
4 cylinder 2 stroke does not seem to have a problem
