Hey, I'm just about ready to order an MS3 system and I've got a question regarding VSS's
I've got an 84 Grand Prix with a T70/5.3/4L80e combo. I'll be using MS3 and a Microsquirt controller for the transmission.
It looks like I can swap some mid 90's S10 backing plates with sensors and rotors with ABS rings in pretty easy to get front VSS worked out. Will I be able to use the 4L80e output speed sensor to provide a rear wheel speed signal to the controller, or will I have to come up with something to adapt a VSS to the Ford 9" diff? I've played around with the software a little bit and slowly starting to understand some of it, but it looks to be a fairly steep learning curve. I just want to be sure this method will actually do the trick.
Regards.
4L80e output speed sensor and traction control
Re: 4L80e output speed sensor and traction control
Yes you can use the vss from the 4L80e for you driven sensor.
I'm assuming you are going to use a micro trans controller for your 4l80. Just follow the instructions page by page and it walks you through it. As long as you do a good job with your wiring you shouldn't have a problem, I didn't.
Good luck
Sent from my SM-G930F using Tapatalk
Good luck
Agreed. I used traction control with my 80e. You'll need to buffer the vr sensor though from the front tire with the 3x setup. A simple 4 pin hei module can be used for this
You can even use the gear indication and run boost by gear with an 80e
