SD Data log Error
SD Data log Error
Need help with my SD data logs. I am using TunerStudio MS Ultra V3.0.22 with MS3 running 1.5.0 Release, which was just recently upgraded from firmware 1.3.0. When I try to download an SD data log I get the following error - did not complete log conversion, reported error:invalid MS3 SD file format. When log viewer asks me if I want to view the log now and I press "yes" then I get the following - Log file contains no data or is not regcognised: if this is an ASCII type file, check the selected file delimiter under the options menu. I have checked under the options menu in Tuner Studio and I couldn't find anything there marked "file delimiter". I am using a Transcend Micro SD 8 GB card, which I believe was one of the listed known cards that worked for SD logging. This card worked with the 1.3.0 firmware. I have provided a copy of my MSQ.
