"Nissan CAS" only refers to the disc with 360 slits. That requires PT4.
Once you fit an aftermarket disc it is a normal "Dual Wheel" or "Dual Wheel with Missing Tooth". The 12 or 24 slots go to the Crank input and the single slot goes to the MS3X Cam input.
VG30E 85 Maxima
Re: VG30E 85 Maxima
Re: VG30E 85 Maxima
so I hooked the outer signal to the MS3X cam input and well she started and runs but has "cam fault" here is composite log, do I need to change it from "poll" to "rising edge" or "falling edge"
https://www.dropbox.com/s/9xyyopsufuwmf ... t.csv?dl=0
Oh and another note, the aftermarket wheel was not just a drop in, I had to modify it to work with mine
Re: VG30E 85 Maxima
Did you ever solve the " cam Fault" error. Having the same issue on a VG30E with DIY 24 =1 wheel. MS3X running with second trigger on Rising edge seems to work OK. But get Cam Fault error. Get Cam fault message on Poll Level = High or Low. Don't know what Tooth to use for Polling. Set at default of " 1 " and that is probably what gives the error. If you used Poll Lvel do you have any recommended settings.vern_k wrote:so I hooked the outer signal to the MS3X cam input and well she started and runs but has "cam fault" here is composite log, do I need to change it from "poll" to "rising edge" or "falling edge"
Have a nice consistent Cam and Trigger signal though. Forgot to grab files from computer. Will get them tomorrow and post .msq and Composite logs.
