Porsche running on only 3 cylinders - EDIS ignition
Re: Porsche running on only 3 cylinders - EDIS ignition
What controller are you using for the GM O2 sensor? What are you using for a CLT sensor and where exactly is it located? The CLT sensor needs to be at the cam tower or in a cylinder fin for realistic readings. Using oil temperature for CLT is too slow for warm up.
Porsche 930 3.0 Slantnose
