cam sensor not displayed on comp logger
ejs262
Post by ejs262 »
I'm in section 2.15 of the manual, and I'm not getting a cam signal on the logger. the dashboard doesn't show cam fault.
I'm assuming this means I need a pull up resistor for the cam signal?
Thoughts?
Thanks for the help.
I'm using TunerStudio MS Ultra version 3.0.22 MS3 firmware 1.5.0
"I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
kaeman
Re: cam sensor not displayed on comp logger
Post by kaeman »
tell us a little more about the sensors and the engine trigger wheel etc. the pull up resistor would be needed on some types of sensors and not needed on others.
ejs262
Post by ejs262 »
kaeman wrote:tell us a little more about the sensors and the engine trigger wheel etc. the pull up resistor would be needed on some types of sensors and not needed on others.
Crank is a 2008 GM 3900 V6 unit on a 36-1 wheel, cam is a 2006 G6 sensor on a wheel with a notch cut into, basically the inversion of a single tooth wheel. both are 3 wire sensors I assume to be hall effect.
ejs262
Post by ejs262 »
both sensors use a 12V source supplied from IGN+
ejs262
Post by ejs262 »
new update, under short cranking, it doesn't display a cam fault, under longer duration cranking it does... time to check some wiring...
ejs262
Post by ejs262 »
new update... it helps to have it plugged in....
DOH!
:oops:
Doesn't look like a pull-up will be necessary to me.
