high voltage with only 12.1 in
Attached is my MSQ and datalog of a quick bench test of the wiring harness and MS3x that has been sitting for a few years.
I dont understand why I am seeing about 22 volts in tunnerstudio and in the datlog. I tried reburning the voltage voltage calibration but no still reads high.
ideas at what is wrong?
Re: high voltage with only 12.1 in
I know nothing about MS3, but I'm wondering about your grounds...............
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
well right now the harness is not in the car so no ground per say. I using a battery and putting 12 volts into the ms where the power relay would normally do so and ground to the power ground normally at the engine.
my multi meter reads 12.1 volts at the between pin 28 and pin 19
Check the voltage on TPSVREF. If there's a short over overload and that is reading low, it will show the Battery voltage as artificially high.
check for dry solder joints on r3 & r6 thats the voltage divider circuit for the battery voltage reading, also measure the voltage on the 5v inside the ecu if the 5v is low the 12v will read higher
James,
I removed the harness and powered pin 28 and grounded pin 19. measuring between ground and pin 26 I am getting 4.7 volts and I am still reading 22 volts on tunerstudio.
I think grom e30 is on the right idea, the soldered joints a bit of brown stuff around them from sitting I guess. I heated R3 and r6 joints with no change.
items to check to narrow down a bad soldiered joint?
mesuring 4.13 volts between pin 1 and pin 2 on the 40 pin connector to the ms3 board
Something is partially shorted.briansexsmith wrote:mesuring 4.13 volts between pin 1 and pin 2 on the 40 pin connector to the ms3 board
11.5 volts on the Vin of U5 and 4.98 volts on the output
0.2 volt drop across the F1 polyfuse
Problem solved! I put the PM2 from the knock board to a ground pin.
Thanks for the help guys! I guess I foolishly installed the knock module and never tested or ran a car in it in years.
