Is it possible to set Flat shift to engage when the input ground is lost instead of when the input is grounded? My stock clutch switch is a Normally Open switch and grounds when the clutch is in the resting position. When I depress the clutch the switch goes off and looses the ground. I know I can wire in a relay to make that work but before I do I was wondering if there was a software toggle to make this much easier.
-Josh
Input trigger from NC to NO configuration
