Info on trans brake,launch control install
Im new to all this and i am trying to get some wiring done on my turbo ls blazer. I have the ms3 ultimate and have everything hooked up just like in the manual.. HIGH current out going to solid state coil side, INput is Digital switch in 3. I got my ppp shifter so when button is pushed it is activating a relay coil because it puts out a 12v out put. so the relay completes circuit to ground on the digital switch in 3 but am not getting anything from the out to my relay. no ohms to ground or anything. Do i have to have truck running for this to work or am i missing something here? i can touch the wire on the solid state that needs to see ground from MS3 to ground and it triggers fine. i can also go to test HIGH CURRENT out and it works. My photo bucket is screwed so looking for new picture hosting site.
Re: Info on trans brake,launch control install
The truck needs to be running.
You can test the output without the engine running using the Test Modes.
great thanks. makes me feel a lil dumb because ive been scratching my head for 2 days about it. haha
