MSPNPPro 2jz-gte ac idle up help
MSPNPPro 2jz-gte ac wiring and configuration help. I have not changed any thing from base tune and it does not idle up or activate the ac clutch. Ac is charged and works with the stock ECU.
Re: MSPNPPro 2jz-gte ac idle up help
First, activate Port Status in the Project Properties; this will let us view if the A/C switch is coming on. Then
