In the case of a hot engine the governor sticks from the TH700R4 transmission
New Governor Sonnax 730
Corvette 1978, transmission from 1992.
What can be the case of this.
Thanks in advance
Harry
Heerlen78
TH700R4
Re: TH700R4
The governor on a 700r4 is not electronically controlled. Only the converter clutch........
OR, did I misunderstand your question?
EDIT: 1992 would be the last year of for the 700r4/4L60...... If it is electronically controlled,it is more likely a 4L60E......
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
