I have a Mazda rx7 FC3S
engine is a 13BT running ms3x 1.4.0
ID1000 primary
ID2000 secondary
I am trying to get the ar ready for a tune with my tuner as he is very busy I am trying to get any gremlins out of the way.
From what I can tell my AFR seems to lean out some time as soon as the secondary injectors come online but after about ~1 second it drops and runs rich or as it should. If I move the staging table the lean spike moves it is also never consistent as to how lean I've seen up to a spike to 15 at 2PSI but usually it is closer to only 12. I am hoping you guys have some ideas on what I can run through or look at
secondary injectors staging?
Re: secondary injectors staging?
Are the secondaries supplied off the same fuel system? If not, is there any chance that their fuel is initially at a different temperature or pressure? A dead-headed fuel rail, for example, may have the fuel get rather hot when the staging is off.
This is how I have my lines setup I don't see a major issue.
I have another log that may give some ideas.
I am mostly curious about how it can go from 10.8 down to 9.9 but only move .8 on the ve table over a 250 RPM and 1.2PSI.
Is it possible I am staging the injectors to quickly?
It might work better if the line ran through one rail, looped through the second, and then went to the regulator.
