I have an SR20 with three wire coil on plug packs, is there any way to use the stock Nissan ignitor with the megasquirt so that I don't have to buy an ignition chip?
Sorry if this is in the wrong forum, I'm new here
SR20 COP ms3 extra setup question
Re: SR20 COP ms3 extra setup question
Sure, just run the MS3X spark outputs to the stock ignition module; it takes a standard 5V logic level signal.
I´ve got ms3X and fwd sr20de with stock CAS, coil+distributor system.
I´ve wired my ms3 internally like MS3XV30 instructions tells me to do in section 5.2.3.
(not sure should it be like 5.2.4) and i´m planning to change that original coil+dizzy into a Vw 4 way logic coil 06A905097.
Is my internal wiring ok or do I need to change it to 5.2.4?
CAS signal needs pull up, like in 6.40?
Power from TPS Vref and 330ohm resistors to both signal wires?
Does that have any affect to tps signal?
Ignition signals goes thru x-board like in logic coil setup should go.
Software settings like in 6.40 and spark output Going High?
Nissan Almera Gti -97. Ms3+extra Flex fuel project.
Not sure about the DE but the DET cas needs a 5V pullup so I assume it's the same for a de, worst case if you don't do it is no signal. In that case just add the pullupnipponi wrote:I´ve got ms3X and fwd sr20de with stock CAS, coil+distributor system.
Sent fra min HUAWEI VNS-L31 via Tapatalk
Ok, I think also that there is´t really any difference in basic operation of those dizzys. Any idea about the rest of my questions? Is that internal wiring ok or do I need to take that jumper wire and resistor off? I´m trying to get this one running in about week or so. Mot check is soon, so I need to get it running and tuned before that.
I've tested the SR20 CAS here and I had it working ok. That's where the settings in the manual came from.
