Misfire caused by sync loss?
Engine is a Kawasaki zx12, turbo. Ms3x running sequential spark and fuel, 24 tooth crank with vr sensor. Single tooth on cam also VR. Between 7 and 10k getting misfire (see screenshot of example of problem) sync loss in logs. Does this look like it's an issue with the crank sensor causing sync loss? AFR goes lean at time of issue. Any help or advice appreciated. Examples of the issue at approx 39.905 and 44.476 in attached log file. Included comp log as example, no issues in this file.
- Attachments
- zx12.msq
- (285.87 KiB) Downloaded 27 times
- 2017-09-30_16.59.22.msl
- (682.58 KiB) Downloaded 28 times
Re: Misfire caused by sync loss?
Yes, looks like you have sync losses. RPM doesn't drop to 0 which I'm used to see...maybe log resolution isn't high enough.
You probably need to run the tooth/sync loggers to find out which VR sensor is the problem. Myself I have a problem with the VR sensor at the crank, will replace it with a Hall sensor since my VR-sensor doesn't seem to have a consistent behavior...
Martin, Sweden
Mopar 512 cui, 8.4 liters, high compression, fuel E85, full sequential control by MS3X, burning rubber just blipping the throttle...
Already tried a resistor 10K parallel to crank sensor ?
Thanks for the reply's, I've taken a coupe of composite logs. I'm seeing a couple of big gaps with no crank signal showing and extra cam signals. Is this what a sync loss will look like? Screenshots of normal composite log and screenshot of error attached.
Post tooth-logs, and post the actual CSV file; not screen-shots.
Composite log attached. Error occurs at record 92
- Attachments
- 2017-09-30_17.43.14_edit.csv
- (1.1 MiB) Downloaded 24 times
In record 92 I don't see a clear sync error, but you have the same empty, 1 second area that I am seeing in my logs. I have so far not seen an explanation of the phenomenon...I have switched laptops, made no difference...
Martin, Sweden
The empty area needs to be investigated by James and Phil. It happens on many cars and many different combinations, and it is very frustrating when you try to troubleshoot a sync loss problem.
The man behind MS Labs
I'm putting the the issue shown at record 92 down to a comms issues when the log was being taken rather than an issue with sync loss. I've found an issue later in the file which I believe is causing my problem (Record 204). There is an extra tooth being recorded right before I get sync loss. It was difficult to see from the logs as it happens very close to the next tooth. See screenshot below. Can anyone tell me how/where should I put the 10k resistor to stop this from happening? Is that the best method to prevent this?
Take the resistor wires an connect each wire to its own VR sensor wire.LAV1000 wrote:Already tried a resistor 10K parallel to crank sensor ?
One resitor wire to one vr sensor wire, the other resistor wire to the other vr sensor wire.
Doesn't matter were, somewhere near the sensor or even in side the MS3x unit.
You have exactly the same extra tooth that I have. I solved it easily by activating the noise filtering in the Ignition Settings meny, you pick the settings needed right out of the microseconds shown in your log.bren32 wrote: Can anyone tell me how/where should I put the 10k resistor to stop this from happening? Is that the best method to prevent this?
Unfortunately the newborn engine power I found (without any sync errors) caused a cabling problem due to more engine movement so I am just about to start testing again...
Martin, Sweden
Thanks for the replies, I'll try the Noise filtering first and see if that helps, if not will try the resistor.
