Need help identifying this MS2/V357
billr
Re: Need help identifying this MS3
Post by billr »
My guess is that it is a baro sensor, so its port should be open to atmosphere.
ponie1992
Post by ponie1992 »
Is it possible to pull the current map from the MS and see what sensors were being used?
Sent from my SM-N950U using Tapatalk
Jeremy
billr
Post by billr »
Sure, you will get the opportunity to load the MSQ from the MS to TS every time you connect to MS.
ponie1992
Post by ponie1992 »
Ok, so I was able to connect to the MS and I think I saved the current map correctly. This is what I got.
Megasquirt_existing_tune_89GT_011718.msq
(117.81 KiB) Downloaded 18 times
Jeremy
billr
Post by billr »
A second sensor for baro isn't enabled in that MSQ, so the question remains: what is that sensor wired to?
Are you sure what kind of device that is, can you post the manufacturer and P/N?
ponie1992
Post by ponie1992 »
billr wrote:A second sensor for baro isn't enabled in that MSQ, so the question remains: what is that sensor wired to?
I believe it says Yitron Technology on it. I'm guessing the part number is what's on the sticker?
I asked the previous owner about it, but can't get a response.
Jeremy
ponie1992
Post by ponie1992 »
Didn't get a chance to trace the wires down. I'll have to do that this weekend.
Jeremy
ponie1992
Post by ponie1992 »
I did notice the vacuum line at the MS goes to the boost/vacuum gauge. There is a T but it's capped off from going anywhere else. Would any of you know if my MS has a built in MAP sensor?
Jeremy
Unless it has been removed, a standard MS2/V357 has an internal MAP sensor yes.
prof315
Post by prof315 »
jsmcortina wrote:Unless it has been removed, a standard MS2/V357 has an internal MAP sensor yes.
And based on the picture of your mainboard it appears to be there.
Support the developers!
ponie1992
Re: Need help identifying this MS2/V357
Post by ponie1992 »
Ah ok. So, just run a vacuum line off the T to the manifold?
Jeremy
rickb794
Post by rickb794 »
Yes if you want the MS and gauge to see manifold vacuum they will need to be connected.
Your TFI wiring and instructions are in section 6.3 of the manual.
Use only the Extra Manuals found here http://www.msextra.com/manuals/ms2manuals/
I think you will find that Tuner Studio (the paid version) is well worth the $.
https://www.efianalytics.com/TunerStudio/faq.html
Blown88GT
Post by Blown88GT »
I'm a little late to this party, but it looks like you're on the right track.
You're '89 is pretty close to my '88.
'88's were Speed Density (except Calif.) They used a MAP sensor on the firewall.
'89's were MAF. They used a BAP sensor on the firewall.
These sensors are not used for the Megasquirt (MS).
I'm still running the TFI.
My Megasquirt is different from yours (see signature), it still uses the factory harness & ECU connector.
The internals are different, too. Both are MS2/Extra
You should use the Ford TPS.
Wonder why yours has an MS3Pro sticker?
ponie1992
Post by ponie1992 »
Blown88GT wrote:I'm a little late to this party, but it looks like you're on the right track.
I soldered in a Ford TPS and actually calibrated it last night. Works great. From what I understand, that's just a sticker and means nothing.
Jeremy
ponie1992
Post by ponie1992 »
rickb794 wrote:Yes if you want the MS and gauge to see manifold vacuum they will need to be connected.
Are you referring to the 3.57 hardware manual?
Jeremy
rickb794
Post by rickb794 »
Yes
The TFI instructions are there.
The MS3Pro sticker gives you a psychological advantage!
ponie1992
Post by ponie1992 »
rickb794 wrote:Yes
Gotcha, have that manual in my phone already. Image
Jeremy
Blown88GT
Post by Blown88GT »
ponie1992 wrote:....that's just a sticker and means nothing.
Only means something if it causes confusion (which it did).
The MS2 can be converted to an MS3 with an add-on board.
https://www.diyautotune.com/product/meg ... board-kit/
rickb794
Post by rickb794 »
"Those that know" will realize that a MS processor will not fit in that case.
And a MS3Pro is a completely different appearing animal.
ponie1992
Post by ponie1992 »
Update: finally heard back from the previous owner. The sensor on the firewall is for the boost sensor he was using. He confirmed I just need to run manifold vacuum to the T before the MS. Thanks for everyone's input on this!
Jeremy
