CAN GPS for VSS
MolsonB
CAN GPS for VSS
Post by MolsonB »
I'm sending CAN GPS to MS3 1.5.1 beta7, and wondering about the settings on the VSS screen. (Attached screenshot) It took me awhile to figure out ms-1 meant meters per second. lol.
Code: Select all
   gps_speed       = scalar, U16,  500, { bitStringValue( prefSpeedUnits ,  prefSpeedUnits ) }, { msToPrefUnitsScale }, 0.0
   gps_speed_ms_1        = scalar, U16,  500, "ms-1", 0.1, 0.0
The VSS position type, what does that do. Since MS3 is polling the CAN GPS at xxx rate, I don't see how Pulses are relevant. Are they used in the calculation? Only have source code for 1.4, so can't dig into it.
Setting the VSS speed, does that really only effect the fuel economy calculations and odometer ?
MolsonB
Re: CAN GPS for VSS
Post by MolsonB »
Bump if anyone knows this screen or code behind it.
Re: CAN GPS for VSS
Post by jsmcortina »
VSS can be recorded in your datalogs, used for gear calculation, for traction control, for trans-brake lockout or for torque converter lockup.. However, a GPS is too slow a source for traction use.
Looks like that field is showing ungreyed in error. Ignore it.
MolsonB
Re: CAN GPS for VSS
Post by MolsonB »
Thanks James, I thought those fields should be grayed out.
I assume the CAN VSS is being used for fuel economy calculations and odometer too?
Re: CAN GPS for VSS
MolsonB wrote:Thanks James, I thought those fields should be grayed out.
The MS3 doesn't perform those calculations, they are configured to occur in TunerStudio.
MolsonB
Re: CAN GPS for VSS
Post by MolsonB »
Ahhh gotcha.
Thanks again James.
