Boost switching 1 controller 2 tables
I'm in the process of setting up hardware activated table switching on a car and I want to switch boost tables as well as VE and spark. But when I try to do so I get a config error concerning the boost control. It says that I can't use the same output for both boost tables. So does this mean I need 2 boost controllers?
- Attachments
- table switch.msq
- (285.17 KiB) Downloaded 27 times
Support the developers!
Re: Boost switching 1 controller 2 tables
Go to Boost Control Settings 2 and change Boost Control Enabled to Off. With it set to On, the ECU isn't sure if the second boost control table is for a completely separate output or an alternate table.
Gotcha thanks Matt!Matt Cramer wrote:Go to Boost Control Settings 2 and change Boost Control Enabled to Off. With it set to On, the ECU isn't sure if the second boost control table is for a completely separate output or an alternate table.
